Go to Post Just remember: the tubes aren't a life saving device, the are a life CHANGING device! - Koko Ed [more]
Unread 05-05-2010, 07:31 PM
davidthefat davidthefat is offline
Alumni
AKA: David Yoon
FRC #0589 (Falkons)
Rookie Year: 2010
davidthefat has much to be proud ofdavidthefat has much to be proud ofdavidthefat has much to be proud ofdavidthefat has much to be proud ofdavidthefat has much to be proud ofdavidthefat has much to be proud ofdavidthefat has much to be proud ofdavidthefat has much to be proud ofdavidthefat has much to be proud of
Using A PS3 With The cRio
Whos down? Think of all the power you have in your hands. Boot up linux and take charge of the SPUs on the PS3, will be the bomb. Why would you need it you ask? Autonomous, See the DARPA Cars, they have like 10-20 PC in the trunk. Its $300 so its under the $400 rule and a lot more potential than Arduino or other tiny things. You see where I am going with this? You will have a bad boy of a robot next year if you fully utilize the autonomous perception, logic and have it run on a PS3. Yes sure the PS3 can not control motors itself (Its illegal too BTW) so it communicates with the cRio using an ethernet cable and the sensors with USB bridged by Arduino and cameras just directly connected by USB. Its genius, My goal would be to utilize a PS3 with Fully Autonomous control next year. My dreams get bigger and bigger...
Resources:
http://www.ibm.com/developerworks/po..._articles.html
http://www.ibm.com/developerworks/vi...e_by=Tutorials
http://www.ibm.com/developerworks/po...ab1/index.html
http://www.ibm.com/developerworks/po...3-1/index.html
http://www.ibm.com/developerworks/po...3-2/index.html
http://www.ibm.com/developerworks/vi...&Go.x=0&Go.y=0
I made this thread because this forum seems to die off after the competition... Keep the fire burning
Do not say what can or cannot be done, but, instead, say what must be done for the task at hand must be accomplished.
How do you run the pneumatics through the CRio w/o using the Jaguars and the Spikes brreadd Pneumatics 3 11-20-2009 03:35 PM
Using Pneumatics with the CRIO? nighterfighter FRC Control System 9 10-18-2009 10:59 PM
Using the cRIO to control custom lights hal_2498 FRC Control System 14 04-10-2009 07:55 AM
Using Sockets with the cRio in Wind River C222 C/C++ 15 02-17-2009 02:10 PM
Using Standard Labview with cRIO writchie FRC Control System 2 01-23-2009 01:44 PM
