Go to Post Dance Dance Revolution is the only solution. That rhymed. I should not be on chief at this hour of the morning. >_< - Eugenia Gabrielov [more]
Unread 05-05-2010, 23:22
548swimmer's Avatar
548swimmer 548swimmer is offline
CAD Leader
AKA: Alec Wagner
FRC #0548 (Robostangs)
Team Role: CAD
548swimmer has much to be proud of548swimmer has much to be proud of548swimmer has much to be proud of548swimmer has much to be proud of548swimmer has much to be proud of548swimmer has much to be proud of548swimmer has much to be proud of548swimmer has much to be proud of
Re: pic: 6 inch wheel design
Originally Posted by M. Mellott View Post
Looks like you could machine the front face of the 3 closest "spokes" and the back side of the other three in one pass. Flip it over and repeat the process.
The outer wall looks like it's recessed for the tread. Does your weight include the tread material, or is it just the wheel?
I like the wider tread. Very nice, Adam!
Just the wheel, but since it's just for a prototype CAD I extruded where the tread would be, so it should be about the same weight.
Unread 05-05-2010, 23:23
Jamie Kalb Jamie Kalb is offline
Jamie Kalb is a name known to allJamie Kalb is a name known to allJamie Kalb is a name known to allJamie Kalb is a name known to allJamie Kalb is a name known to allJamie Kalb is a name known to all
Pretty neat.
For the "free" wheel, if the hub is wider than the rim, you can attach a flat sprocket directly to the (nicely integrated) bolt pattern on the wheel without an extra spacer. I can't tell from the picture if it's already like that.
Team 3129 Green MacHHHHine Founder, Captain (2009-10), Alumnus, and Mentor (2011-14)
2011-13 VEX World Championship...
pic: 4 inch Wheel Render Chris is me Extra Discussion 25 15-05-2010 18:43
pic: 4 Inch Wheel Design MWB Extra Discussion 43 06-05-2010 19:32
4 inch Wheel of Doom R.C. SolidWorks 25 26-11-2008 23:57
pic: 5 Inch Wheel RMS11 Extra Discussion 24 18-08-2008 23:55
12 Inch Wheel Available in Several Formats Ed Sparks Inventor 1 19-01-2004 07:12
