Go to Post Rules are after all rules. They don't have to make sense. - ChrisH [more]
Go Back   Chief Delphi > Technical > CAD > Inventor
Unread 06-05-2010, 16:01
jamie_1930's Avatar
jamie_1930 jamie_1930 is offline
FRC #2228 (Cougartech)
Team Role: Student
jamie_1930 is a splendid one to beholdjamie_1930 is a splendid one to beholdjamie_1930 is a splendid one to beholdjamie_1930 is a splendid one to beholdjamie_1930 is a splendid one to beholdjamie_1930 is a splendid one to beholdjamie_1930 is a splendid one to behold
Making a picture part of a sketch
I'm wondering is there a way in which you can import a picture into inventor and then take that picture and make it part of the sketch, so you can cut it out of piece. My end goals is to be able to cut out our teams cougar logo onto a piece of sheet metal, I've seen this on some robots this year like 48, had on their wheel brackets, and 1902 had on their chassis.
Team 2228(FRC) - Drive Team Lead, Drive Coach, Mechanical Team
Team 3750(FTC) - Team Lead
2009
Team 2228(FRC) - Mechanical Team, Driver at RIT, and Hartford Regionals, and Drive coach at Ruckus
*Second Place at Ruckus
Team 3750(FTC) - Team Lead, and Drive coach at Clarkson Regional
*Second Place at Clarkson Regional
2008
Team 1930(FRC) - Worked on Mechanical, Electrical, and Programming.
Unread 06-05-2010, 16:16
RMS11's Avatar
RMS11 RMS11 is offline
Safety!!!!
AKA: Rick
FRC #2415 (WiredCats)
Team Role: Driver
RMS11 is a splendid one to beholdRMS11 is a splendid one to beholdRMS11 is a splendid one to beholdRMS11 is a splendid one to beholdRMS11 is a splendid one to beholdRMS11 is a splendid one to behold
Send a message via AIM to RMS11
Re: Making a picture part of a sketch
I found one way is to import a picture, scale it to proper size, then trace it with the spline feature. If there is a better way to do this, I would love to know.
2009 Peachtree Regional Champs
2009 Palmetto Regional Champs
2008 Peachtree Rookie All Star and Rookie Highest Seed
Unread 06-05-2010, 16:19
AdamHeard's Avatar
Lead Mentor
FRC #0973 (Greybots)
This is the method I've used in inventor and solidworks.
Unread 06-05-2010, 16:30
roystur44's Avatar
roystur44 roystur44 is offline
Mentor/Sponsor
AKA: Roy Dumlao
FRC #4543 (Apollo Robotics)
roystur44 has a reputation beyond reputeroystur44 has a reputation beyond reputeroystur44 has a reputation beyond reputeroystur44 has a reputation beyond reputeroystur44 has a reputation beyond reputeroystur44 has a reputation beyond reputeroystur44 has a reputation beyond reputeroystur44 has a reputation beyond reputeroystur44 has a reputation beyond reputeroystur44 has a reputation beyond reputeroystur44 has a reputation beyond repute
Send a message via Yahoo to roystur44
Wink Re: Making a picture part of a sketch
Jaime,
Take a look at a program called Inkscape.
Roy
Unread 06-05-2010, 17:13
A_Reed's Avatar
A_Reed A_Reed is offline
Lead Design Mentor
AKA: Adam Reed
FRC #0048 (Delphi E.L.I.T.E)
A_Reed is a splendid one to beholdA_Reed is a splendid one to beholdA_Reed is a splendid one to beholdA_Reed is a splendid one to beholdA_Reed is a splendid one to beholdA_Reed is a splendid one to beholdA_Reed is a splendid one to behold
That is the exact method I used to make the 48 cut outs in our wheel plates this year. The spline feature isn't that hard to use and lock down to get your desired graphics. It also helps to have access to a water-jet as you can draw the exact image without having to worry about machine standards and standard shapes.
Unread 06-05-2010, 17:24
RMS11's Avatar
Safety!!!!
AKA: Rick
Team Role: Driver
Did you make this image first in photoshop or something similar?
Unread 06-05-2010, 17:32
A_Reed's Avatar
Lead Design Mentor
AKA: Adam Reed
Nope, I just did a Google image search for Jimmie Johnson's 48 logo and used one of the results. You can scale and rotate your image inside the sketch to get it sized to fit where you need it.
Example
Unread 08-05-2010, 14:54
jamie_1930's Avatar
Team Role: Student
Wanted to give everyone a little update on how this worked and thank you for the help. First off this is the design I wanted to cut into a piece of sheet metal.
So I was really hoping there would be an easier way to do this than tracing the picture with spline, but I finally sat down and did it, and I got to say it wasn't as grueling as I thought it would be and I think it turned out great.
This is actually the assembly where I have two sheets the black one has the design cut out, and the yellow is just a back plate. I got that idea from 1902 so again thank you guys for the inspiration.
2009
2008
Unread 08-05-2010, 14:58
vivek16's Avatar
vivek16 vivek16 is offline
Whoa! college pilot.
AKA: vivek
FRC #2264 (trojan robotics)
Rookie Year: 2007
vivek16 has a reputation beyond reputevivek16 has a reputation beyond reputevivek16 has a reputation beyond reputevivek16 has a reputation beyond reputevivek16 has a reputation beyond reputevivek16 has a reputation beyond reputevivek16 has a reputation beyond reputevivek16 has a reputation beyond reputevivek16 has a reputation beyond reputevivek16 has a reputation beyond reputevivek16 has a reputation beyond repute
Send a message via AIM to vivek16 Send a message via MSN to vivek16
if you're gluing the sheets together, how are you going to keep the random "floater" pieces attached to the rest of the cutout?
"we don't build robots, we build people"
Unread 08-05-2010, 15:43
jamie_1930's Avatar
Team Role: Student
Sorry about that I wanted to show you guy's this picture
which does have supports added in.
P.S. I don't plan on ever gluing 1/8" sheet metal together ;D
2009
2008
Google Sketch Up -- Don't Laugh Gdeaver CAD 3 21-01-2009 01:10
Need Help Making Part from Spec Goaliexam Inventor 10 26-07-2006 11:34
New sketch. from 1657# Ami Schwartz General Forum 3 19-02-2006 15:25
Ramp Sketch archiver 2000 0 24-06-2002 00:09
Square Rack Sketch archiver 2000 1 24-06-2002 00:09
