Go to Post Messy wires are a pain in the chassis - [more]
Go Back   Chief Delphi > Technical > CAD > Inventor
Unread 06-05-2010, 19:40
tiger1dd tiger1dd is offline
FRC #1293
Team Role: CAD
tiger1dd is an unknown quantity at this point
6 Wheel Drive, Wheel/Drive Assembly
I'm the newbie, and since I'm the only non-college person on the team that can use inventor, I've been assigned to create a six wheel drive. I was wondering where I could maybe get the different parts to the wheel assemblies+dimensions, as well as some different wheel designs, dimensions, and if you could even post any ipt files for me to analyze, that would be great. Sorry I'm asking so much, I just got a big load put on my back.
Thanks in advance!
Unread 06-05-2010, 19:47
CraigHickman
Posts: n/a
Re: 6 Wheel Drive, Wheel/Drive Assembly
Take some time to browse the images in CDmedia. Especially search for 6 wheel drives, and check out the West Coast drives for the most minimalist approaches to this. Once you're familiar with what is out there, model every part yourself. Taking shortcuts will get you through a build season, but doing it right can get you a job.
Unread 06-05-2010, 19:53
FRC #1293
Team Role: CAD
Alright, I found the Cdmedia, where can I find West Coast Drives, inside CDMedia?
Thanks!
Unread 06-05-2010, 20:03
Adam.garcia Adam.garcia is offline
Design Mentor
FRC #0004 (Team 4 Element)
Rookie Year: 1997
Adam.garcia is just really niceAdam.garcia is just really niceAdam.garcia is just really niceAdam.garcia is just really nice
Talking Re: 6 Wheel Drive, Wheel/Drive Assembly
Hello,
Check these websites out! They have a lot of parts already designed in inventor, which you can use.
http://www.firstcadlibrary.com/
http://www.3dcontentcentral.com/part...rue&l evel=10
These will help you get started with designing an actual robot.
If you have any questions, just pm me and I'll be glad to help!
Thanks,
Adam
Unread 06-05-2010, 20:09
FRC #1293
Team Role: CAD
WOW! Those two links were exactly what I needed. I'll post what I make shortly. Thank both of you guys so much!
Unread 06-05-2010, 23:26
Edoc'sil's Avatar
Edoc'sil Edoc'sil is offline
FRC #2531
Rookie Year: 2007
Edoc'sil has a spectacular aura aboutEdoc'sil has a spectacular aura about
The simplest 6 wheel drive to build is two traction wheels in the middle and omnis on the corners. No issues turning at all, but it can be pushed in a circle if its hit just right. we loved the maneuverability that this drive offered us this year.
Love to see what you come up with.
Here lies a toppled god-
His fall was not a small one.
We did but build his pedestal,
A narrow and a tall one.
Unread 07-05-2010, 01:24
dtengineering's Avatar
dtengineering dtengineering is offline
Teaching Teachers to Teach Tech
AKA: Jason Brett
no team (British Columbia FRC teams)
dtengineering has a reputation beyond reputedtengineering has a reputation beyond reputedtengineering has a reputation beyond reputedtengineering has a reputation beyond reputedtengineering has a reputation beyond reputedtengineering has a reputation beyond reputedtengineering has a reputation beyond reputedtengineering has a reputation beyond reputedtengineering has a reputation beyond reputedtengineering has a reputation beyond reputedtengineering has a reputation beyond repute
And before you start assuming that you have to make it out of metal...
also search the CD media photos for "wood" and "plywood".
Or fibreglass (particularly what 842 does with it.)
Jason
Unread 07-05-2010, 02:31
CraigHickman
Posts: n/a
Jason
This! Very this! I've been trying to convince a few team members to try a bamboo robot for a few years now...
Unread 07-05-2010, 08:13
Edoc'sil's Avatar
FRC #2531
Rookie Year: 2007
How well does the fiberglass hold up? I have used it for other applications and it doesn't see to be robust enough for FIRST, but then again neither does balsa, and I have seen those bots.
Unread 07-05-2010, 10:44
JamesCH95's Avatar
JamesCH95 JamesCH95 is offline
Hardcore Dork
AKA: JCH
FRC #0095 (The Grasshoppers)
JamesCH95 has a reputation beyond reputeJamesCH95 has a reputation beyond reputeJamesCH95 has a reputation beyond reputeJamesCH95 has a reputation beyond reputeJamesCH95 has a reputation beyond reputeJamesCH95 has a reputation beyond reputeJamesCH95 has a reputation beyond reputeJamesCH95 has a reputation beyond reputeJamesCH95 has a reputation beyond reputeJamesCH95 has a reputation beyond reputeJamesCH95 has a reputation beyond repute
McMaster has CAD files of almost everything they sell, so if you find a bearing, bolt, sprocket, or widget that you like in their catalog, go ahead and download it!
Theory is a nice place, I'd like to go there one day, I hear everything works there.
Maturity is knowing you were an idiot, common sense is trying to not be an idiot, wisdom is knowing that you will still be an idiot.
Unread 07-05-2010, 11:52
sdcantrell56's Avatar
sdcantrell56 sdcantrell56 is offline
AKA: Sean
FRC #2415 (Wired Cats)
sdcantrell56 has a reputation beyond reputesdcantrell56 has a reputation beyond reputesdcantrell56 has a reputation beyond reputesdcantrell56 has a reputation beyond reputesdcantrell56 has a reputation beyond reputesdcantrell56 has a reputation beyond reputesdcantrell56 has a reputation beyond reputesdcantrell56 has a reputation beyond reputesdcantrell56 has a reputation beyond reputesdcantrell56 has a reputation beyond reputesdcantrell56 has a reputation beyond repute
Fiberglass holds up extremely well in a FIRST setting. Im not sure of any team who has used plain balsa for there robot. We use baltic birch plywood and it is incredibly strong and easy to work with
Mentor 2415
Unread 07-05-2010, 12:04
Chris is me's Avatar
AKA: Pinecone
Pulturded fiberglass is beastly for FIRST. Main problem is it weighs a lot, but you can be shockingly liberal with lightening and it will still hold strong. 2791 used it this year to make a bumper frame for roughly 7 pounds. It's great because you can machine them in any school wood shop, and pultruded fiberglass already has some convenient flanges for structure. 1726 has used it for a cantilevered dead axle 6wd before and it seemed to work for them; their bases are a little heavy but they don't tip! I might make some pultruded fiberglass CAD now...
In many applications you may prefer bent aluminium though. We replaced a lot of square fiberglass tubing with kitbot c-channel and saved a lot of weight.
Unread 07-05-2010, 12:13
Andrew Schreiber Andrew Schreiber is offline
Data Nerd
FRC #0079
Rookie Year: 2000
Andrew Schreiber has a reputation beyond reputeAndrew Schreiber has a reputation beyond reputeAndrew Schreiber has a reputation beyond reputeAndrew Schreiber has a reputation beyond reputeAndrew Schreiber has a reputation beyond reputeAndrew Schreiber has a reputation beyond reputeAndrew Schreiber has a reputation beyond reputeAndrew Schreiber has a reputation beyond reputeAndrew Schreiber has a reputation beyond reputeAndrew Schreiber has a reputation beyond reputeAndrew Schreiber has a reputation beyond repute
This post raised a very good point. The trend seems to be to make your base as lightweight as possible. The upsides to this are obvious but the major downside is that it may mean your CG is higher in the air. This doesn't mean you want a 90lb drive train but is just meant as a warning to check where your CG will be. A good drive train is only useful when it has wheels on the ground.
Where does 1771 source its baltic birch? Is it a local supplier or is it online? Ive been wanting to price it out to see if some projects would be cheaper using wood. (Plus, they would look nice imho)
Unread 07-05-2010, 13:26
JamesCH95's Avatar
Hardcore Dork
AKA: JCH
Pulturded fiberglass is beastly for FIRST [...] It's great because you can machine them in any school wood shop
I hope you're machining that wet...the dust is terrible for people and machine equipment.
Lowered Center Wheel for 6 wheel drive 987HighRoller Technical Discussion 37 17-01-2007 01:21
pic: Jester Drive:Mecanum Wheel Drive Train Ken Delaney 357 Technical Discussion 64 29-03-2006 22:16
pic: Chantilly Academy's 4 Wheel Drive 4 Wheel Steering!!!! jskene Robot Showcase 25 18-02-2005 20:24
pic: 885 Right-center wheel and drive assembly CD47-Bot Robot Showcase 2 30-04-2004 18:27
2-wheel versus 4-wheel drive Ben Mitchell Technical Discussion 23 07-11-2003 00:50
