Set Jaguar device number via cRIO
EDIT: I've reposted this in the CAN forum here. Please delete this thread.
So I finally got the time to try out CAN. However, I can't seem to address my black Jaguar. Here's the setup: 1 black jaguar, connected to cRIO via serial 1 120 ohm resistor between CAN_H and CAN_L Here's the code I'm using: ![]() The enumeration command returns one element with a value of 0. If I interrupt the CAN or serial communication in any way (unplugging a cable, removing the termination resistor, or removing power to the jaguar), it returns an empty array. There's a couple documents saying that the default device number for a Jaguar is 1. Sounds like my results are a little strange. Pressing the "user button" on the Jaguar doesn't have any effect on the return of the enumeration command. Is there anything I'm doing wrong? Last edited by kamocat : 05-08-2010 at 10:26 PM. |
| Routing Camera output via the cRIO | taichichuan | C/C++ | 4 | 03-28-2016 11:13 AM |
| Set computer to receive it's IP via DHCP? | grosh | FRC Control System | 21 | 05-28-2010 04:33 PM |
| CAN Jaguar code set up as a VxWorks Library | taichichuan | CAN | 0 | 02-21-2010 10:16 PM |
| Unable to set team number | Erebos | FRC Control System | 4 | 01-27-2009 05:00 PM |
| Can not set team number on DS | TekClaz | FRC Control System | 2 | 12-23-2008 02:25 PM |
