Go to Post To give credit where credits due, thanks to the GDC for this update. - Brandon Holley [more]
Unread 05-11-2010, 03:53 PM
Schuyoff Schuyoff is offline
FRC #2904
Schuyoff is an unknown quantity at this point
downloading issue
Hi i can connect to the cRIO and "download" but i don't think that it is downloading my program to the right place. when i right click the .out file and download it downloads it to the cRIO but everytime i restart the robot it deletes itself so i have come to the conclusion that i downloaded it to the RAM and thus is has a phyiscal memory dump every shutdown. can anyone fix this?
Unread 05-11-2010, 04:00 PM
nighterfighter nighterfighter is offline
1771 Alum, 1771 Mentor
AKA: Matt B
FRC #1771 (1771)
Rookie Year: 2007
nighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant futurenighterfighter has a brilliant future
Re: downloading issue
You are using Windriver correct? And using the FIRST->Download button?
Also, how do you know it is deleting your code?
Does it say "No Code"? If so, that could be a different error such as undefined symbols, AKA- A problem in your code.
Unread 05-11-2010, 04:06 PM
FRC #2904
i tried first download but it had the same effect.
when i rebooted i went into the driver station and it said "no code".
Unread 05-11-2010, 04:14 PM
FRC #2904
oh and i was using the simple robot template and i didnt do anything to it.
Unread 05-11-2010, 06:04 PM
Radical Pi Radical Pi is offline
Putting the Jumper in the Bumper
AKA: Ian Thompson
FRC #0639 (Code Red Robotics)
Rookie Year: 2010
Radical Pi has a spectacular aura aboutRadical Pi has a spectacular aura aboutRadical Pi has a spectacular aura about
Did you set up the FIRST downloader to work with your project? Go to Window->Preferences (I think) and click on FIRST downloader. Enter your team number and locate the .out file for your project.
"To have no errors would be life without meaning. No strugle, no joy"
"A network is only as strong as it's weakest linksys"
Unread 05-14-2010, 03:22 PM
masoug's Avatar
masoug masoug is offline
Food Consumer
FRC #0114
masoug is an unknown quantity at this point
Have you tried FTP to it? (10.xx.yy.1 Username:FRC Password:FRC, where xx is the first two digits of your team # and yy is the last two digits.)
It is supposed to be under the "ni-rt" directory and called "FRC_UserProgram.out".
How do you do that? RAM (literally) can only be accessed by the computer itself...
-Masoug
JabbaScript
Unread 05-14-2010, 08:38 PM
byteit101's Avatar
byteit101 byteit101 is offline
WPILib maintainer (WPI)
AKA: Patrick Plenefisch
no team (The Cat Attack (Formerly))
byteit101 is a glorious beacon of lightbyteit101 is a glorious beacon of lightbyteit101 is a glorious beacon of lightbyteit101 is a glorious beacon of lightbyteit101 is a glorious beacon of lightbyteit101 is a glorious beacon of light
It's done with the Run/Debug (popcorn!) kernel task command in Windriver. WR sends it to the cRIO, which immediately loads it into memory, and runs it without saving it to a file.
Bubble Wrap: programmers rewards
Watchdog.Kill();
printf("Watchdog is Dead, Celebrate!");
How to make a self aware robot: while (∞) cout<<(sqrt(-∞)/-0);
Previously FRC 451 (The Cat Attack)
Now part of the class of 2016 at WPI & helping on WPILib
Downloading error dnrobotics11 C/C++ 2 02-02-2009 06:52 PM
Downloading help Lyrix NI LabVIEW 1 01-22-2009 12:39 AM
An Issue with downloading the Master Code. Neil [Coconuts] Programming 6 02-07-2008 02:03 PM
Issue with downloading code to the 2007 RC thefro526 Programming 3 02-10-2007 05:26 PM
downloading problems. Dylan Gramlich VEX 9 12-13-2006 01:03 PM
