Go to Post When you are at the regional no one cares if you are a rookie. You are a part of the family. - scitecteach [more]
Unread 12-05-2010, 00:20
Re: The Center Wheel
If you are also concerned about the amount of teetering you're getting from a dropped center, make sure your outer wheels are as far apart as you can go. Its an obvious solution to a very minor problem once CG is maintained as close to the center of your robot as possible (barring any intentional CG changes given certain manipulators).
Unread 12-05-2010, 00:43
Cory's Avatar
Cory Cory is offline
AKA: Cory McBride
FRC #0254 (The Cheesy Poofs)
From the experience we've had with a dropped center 6WD the rock has never been a problem. Not once.
2001-2004: Team 100
2006-Present: Team 254
Unread 12-05-2010, 00:44
CraigHickman
Posts: n/a
Same here.
Unread 12-05-2010, 00:48
Eugene Fang's Avatar
Eugene Fang Eugene Fang is offline
The Blue Alliance
Rookie Year: 2000
Eugene Fang has a reputation beyond reputeEugene Fang has a reputation beyond reputeEugene Fang has a reputation beyond reputeEugene Fang has a reputation beyond reputeEugene Fang has a reputation beyond reputeEugene Fang has a reputation beyond reputeEugene Fang has a reputation beyond reputeEugene Fang has a reputation beyond reputeEugene Fang has a reputation beyond reputeEugene Fang has a reputation beyond reputeEugene Fang has a reputation beyond repute
Same here, too. You don't need a lot of "drop" to get the effect you want. And that little amount of drop results in a barely noticeable rock.
Eugene Fang
2010 Silicon Valley Regional Dean's List Finalist
Various FLL Teams - Student (2000-2006), Mentor (2007-2010)
FRC Team 604 - Student (2007-2010), Mentor/Remote Advisor (2011-2015)
FRC Team 1323 - Mentor/Remote Advisor (2011-2014)
The Blue Alliance | TBA GameDay | TBA Android App
Unread 12-05-2010, 10:20
RoboTIP RoboTIP is offline
AKA: Jackie Moore
FRC #1739 (Chicago Knights)
RoboTIP will become famous soon enoughRoboTIP will become famous soon enough
Originally Posted by squirrel View Post
Don made a great suggestion (as usual), try some different things and see how it works.
And you can play engineer first, figure out what will happen using math and physics equations, then see how close your predictions are to your experimental results.
excellent idea! Anyone willing to share the relevant equations?
Unread 12-05-2010, 10:31
Jon Stratis's Avatar
Jon Stratis Jon Stratis is online now
Electrical/Programming Mentor
FRC #2177 (The Robettes)
Whenever we've done 6-wheel designs, we've dropped the center wheel. In Overdrive, we had a forklift-like elevator that got up probably 10 feet high with dropped center wheels... and we never tipped over. We also had a giant steel plate on the bottom of the robot to lower the CG.
Dropping the center wheel a fraction of an inch does make the robot look a little unstable as it bounces between front and back wheels, this is true. But in reality, if your CG is fairly low, it introduces no risk of tipping while on flat ground (and even climbing ramps in Rack and Roll it didn't seem to matter).
You may want to create a small test bed to see the results and prove it to yourself. Create a standard robot chassis with 6 wheels, but make the center wheel's height adjustable for example, you could securely mount a screw vertically that, when tightened, pushed the axle downwards, giving you a dropped center wheel, assuming you're using dead axle's). Drive it around with both dropped center and non-dropped center, and see how it handles with each. Design some tests for stability to determine if that would be a problem. In short, get some data before you decide which way to go.
Unread 12-05-2010, 10:42
Joe Ross Joe Ross is offline
FRC #0330 (Beachbots)
Rookie Year: 1997
http://www.chiefdelphi.com/media/papers/1443
Unread 12-05-2010, 11:05
ajlapp ajlapp is offline
AKA: Anthony Lapp
None #0118 (Team RUSH and Robonauts)
Rookie Year: 1996
ajlapp has a reputation beyond reputeajlapp has a reputation beyond reputeajlapp has a reputation beyond reputeajlapp has a reputation beyond reputeajlapp has a reputation beyond reputeajlapp has a reputation beyond reputeajlapp has a reputation beyond reputeajlapp has a reputation beyond reputeajlapp has a reputation beyond reputeajlapp has a reputation beyond reputeajlapp has a reputation beyond repute
How about making your drop adjustable?
Also remember that you can drop the center wheel or lift the outer wheel.
When making an adjustable setup it may be easier to lift the outer wheels that probably are not interfaced with your transmission directly.......depending on the rest of your design.
Anthony Lapp
FIRST Engineering Mentor
Owner/Operator 221 Robotic Systems
221 Robotics Systems - Quality Hardware, Made in the USA
RobotOpen
anthony@221robotics.com
Twitter us: @221RobotSystems
Team 1 --> 94 --> 68 --> 221 --> 857 --> 27 --> 118
Design Engineer/Fabricator and 17 year vet
Team Rush (FRC27) and Robonauts (FRC118)
Unread 12-05-2010, 14:05
AKA: Jackie Moore
Originally Posted by Joe Ross View Post
thanks!
Unread 11-05-2010, 23:09
jamie_1930's Avatar
jamie_1930 jamie_1930 is offline
FRC #2228 (Cougartech)
Team Role: Student
jamie_1930 is a splendid one to beholdjamie_1930 is a splendid one to beholdjamie_1930 is a splendid one to beholdjamie_1930 is a splendid one to beholdjamie_1930 is a splendid one to beholdjamie_1930 is a splendid one to beholdjamie_1930 is a splendid one to behold
It seems like that your problem with dropping the wheel is just because you think it will decrease the robot's stability, which in my opinion it will although I don't have an answer for you on how much, but if this is your problem I say go with your instincts and keep them at the same level. Although in order to gain some of the manueverabilty that dropping allows, make your outer wheels omni wheels and have your center wheel be traction.
On a different note and this is something I think we'll be trying in the offseason is, and we stole this from SparX (1126), do a 6 wheel with a 1/8" center drop, with the center wheel be traction wheels along with one of the outer sets. While having the other end be omnis, this will change the bot in a way that if you go in one direction, so all traction wheels are touching, you have more traction to the ground, or travel in the opposite direction, with one set of traction and one set of omni wheels touching the ground, which will give you more maneuverability
Team 2228(FRC) - Drive Team Lead, Drive Coach, Mechanical Team
Team 3750(FTC) - Team Lead
2009
Team 2228(FRC) - Mechanical Team, Driver at RIT, and Hartford Regionals, and Drive coach at Ruckus
*Second Place at Ruckus
Team 3750(FTC) - Team Lead, and Drive coach at Clarkson Regional
*Second Place at Clarkson Regional
2008
Team 1930(FRC) - Worked on Mechanical, Electrical, and Programming.
Adjustable Way of Dropping the Center Wheel R.C. Technical Discussion 15 06-08-2008 18:37
Lowered Center Wheel for 6 wheel drive 987HighRoller Technical Discussion 37 17-01-2007 01:21
Center to Center Distance for 2002 Chaiphua and Cluster gear sanddrag Motors 1 20-07-2005 07:36
pic: 885 Right-center wheel and drive assembly CD47-Bot Robot Showcase 2 30-04-2004 18:27
center-wheel drive Mercutio Technical Discussion 27 02-02-2004 21:19
