Go to Post I am the Evil Empire of FIRST!!! - Andy Grady [more]
Unread 14-05-2010, 23:43
rsisk's Avatar
rsisk rsisk is offline
The GURU Channel
AKA: Richard Sisk
FRC #2493 (Robokong)
Rookie Year: 2007
Cannot communicate with game adapter
I've read through the many threads on CD about resetting the network for the robot after a competition, have done it successfully several times on different robots, and I follow the directions in the manual each time, but this time I ran into a situation I have not encountered before.
After reseting the network according to the manual, I could not ping the gaming adapter on the robot from the classmate. I could ping the router 10.x.y.4, I could ping the gaming adapter if I ran a cable from the router to the gaming adapter 10.x.y.1. But try as I might, I could not ping it wirelessly.
Now here is where it gets interesting, I had another classmate, so I configured the network on the Classmate 2, identical to the Classmate 1 above 10.x.y.15. I did an ipconfig /all on both computers to compare the configuration and they were exactly the same (except for the MAC address of course). I could plug the network cable into Classmate 2 and ping the gaming adapter all day. Plug the network cable into classmate 1, not able to ping the gaming adapter.
The only conclusion I can come to is a problem with Classmate 1, although I'll be darned if I can even begin to describe what that might be.
Any ideas?
The views expressed are mine and should not be construed to represent the views of anyone else.
Unread 15-05-2010, 08:24
Re: Cannot communicate with game adapter
You may want to verify that the wifi is off on the bad classmate. My guess is that the IPs of the wifi are different, or the metric values are different, and the first classmate is trying to ping wirelessly.
Also, does the second classmate do more than ping correctly? If it works as a DS to the robot, or can ping the robot, then I'd say you have shown it is not the bridge and is the first classmate. If the second still cannot ping the robot, then they are different symptoms, but there still might be an issue with the bridge.
Greg McKaskle
Unread 15-05-2010, 09:42
David Brinza's Avatar
David Brinza David Brinza is offline
Lead Mentor, Lead Robot Inspector
FRC #0980 (ThunderBots)
David Brinza has a reputation beyond reputeDavid Brinza has a reputation beyond reputeDavid Brinza has a reputation beyond reputeDavid Brinza has a reputation beyond reputeDavid Brinza has a reputation beyond reputeDavid Brinza has a reputation beyond reputeDavid Brinza has a reputation beyond reputeDavid Brinza has a reputation beyond reputeDavid Brinza has a reputation beyond reputeDavid Brinza has a reputation beyond reputeDavid Brinza has a reputation beyond repute
Richard,
Thanks for working with Team 980 on this most perplexing issue. My darned day-job got in the way, so we only had a little time on Thurs morning to try to get our DS talking with the robot for the demo. Based on an earlier post from Mark McLeod, turning off the bridge wireless security should have been a simple bang-bang procedure. Hah!
Maybe others have had similar issues? First, we'll check the wireless setting on Classmate 1. If we still have an issue, we have access to a second Classmate (from our friends on 2404). We can resume side-by-side testing to see if we can isolate the problem. Perhaps we'll need to re-image Classmate 1?? Fortunately, we've got a lot of time until IRI.
"There's never enough time to do it right, but always time to do it over."
2003 AZ: Semifinals, Motorola Quality; SoCal: Q-finals, Xerox Creativity; IRI: Q-finals
2004 AZ: Semifinals, GM Industrial Design; SoCal: Winners, Leadership in Controls; Championship: Galileo #2 seed, Q-finals; IRI: Champions
2005 AZ: #1 Seed, Xerox Creativity; SoCal: Finalist, RadioShack Controls; SVR: Winners, Delphi "Driving Tomorrow's Technologies"; Championship: Archimedes Semifinals; IRI: Finalist
2007 LA: Finalist; San Diego: Q-finals; CalGames: Finalist || 2008 San Diego: Q-finals; LA: Winners; CalGames: Finalist || 2009 LA: Semifinals; Las Vegas: Q-finals; IRI: #1 Seed, Finalist
2010 AZ: Motorola Quality; LA: Finalist || 2011 SD: Q-finals; LA: Q-finals || 2013 LA: Xerox Creativity, WFFA, Dean's List Finalist || 2014 IE: Q-finals, LA: Finalist, Dean's List Finalist
2016 Ventura: Q-finals, WFFA, Engineering Inspiration
Unread 15-05-2010, 10:15
rsisk's Avatar
The GURU Channel
AKA: Richard Sisk
Rookie Year: 2007
Greg,
Turning off the WiFi is the one of first things I do on the classmate to avoid conflicts, so I am pretty sure it was off during the diagnosis. Wouldn't hurt to try again to confirm.
Also tried multiple network cables, deleted and reinstalled the device in the device manager, made sure other routers nearby were turned off (we were running three robots with three complete network setups).
Dave,
np, I'm always up for a good challenge ;> Reimaging the classmate would certainly eliminate software as one of the remaining variables.
Unread 26-05-2010, 15:46
Bryan Herbst's Avatar
Bryan Herbst Bryan Herbst is offline
AKA: Bryan
FRC #2052 (KnightKrawler)
Rookie Year: 2007
Bryan Herbst has a reputation beyond reputeBryan Herbst has a reputation beyond reputeBryan Herbst has a reputation beyond reputeBryan Herbst has a reputation beyond reputeBryan Herbst has a reputation beyond reputeBryan Herbst has a reputation beyond reputeBryan Herbst has a reputation beyond reputeBryan Herbst has a reputation beyond reputeBryan Herbst has a reputation beyond reputeBryan Herbst has a reputation beyond reputeBryan Herbst has a reputation beyond repute
2052 is also having issues connecting to our bridge.
In the basic settings we disabled WPA (security is set to none), and we also tried turning off the "extra wifi protection."
Team 2052- Knightkrawler
Mentor and volunteer
Unread 26-05-2010, 16:03
rsisk's Avatar
The GURU Channel
AKA: Richard Sisk
Rookie Year: 2007
Have you tried pinging the Gaming Adapter with a standard ethernet cable connecting the router to the gaming adapter?
If you cannot ping the gaming adapter when wired to the router, then you have some other configuration problem and should reset both devices and follow the instructions in section 2.10 of the FRC Control Systems manual to configure the devices.
If you can ping the adapter, then you might have the same problem as we were having. Not sure if a solution has been found for our problem yet. I'll check and post later when I find out.
Unread 26-05-2010, 16:21
AKA: Bryan
Rookie Year: 2007
We just reset both the gaming adapter and router to factory settings and went through the entire set up process again, to no avail.
Unread 27-05-2010, 01:35
rsisk's Avatar
The GURU Channel
AKA: Richard Sisk
Rookie Year: 2007
Are you using the WRT160N Router like in this picture:
If so, did you follow this step when configuring the gaming adapter?
Code:
2.10.1 Step 8
NOTE: When using the WRT160N the “802.11 Band” option should be set to 2.4GHz
Unread 27-05-2010, 15:43
AKA: Bryan
Rookie Year: 2007
Yes, both the gaming adapter and router are set to 2.5GHz.
Unread 27-05-2010, 16:10
rsisk's Avatar
The GURU Channel
AKA: Richard Sisk
Rookie Year: 2007
OK, that's about the limit of my skills.
If you have another classmate, try testing the network with it. If that works, then you are at the same point as 980 and the next step is to reimage the classmate.
If you do reimage, make sure you have any data you want to survive the process backed up, namely your software if you were developing on the classmate.
Sorry I don't have any more suggestions at this point. If you do reimage and that fixes the problem, please be sure to post your results.
Unread 28-05-2010, 15:53
AKA: Bryan
Rookie Year: 2007
While we certainly can consider reimaging the classmate, I do not believe that is the problem.
Then everything is tethered, we can reach the gaming bridge (via 10.20.52.1) and the router (10.20.52.4), but the gaming adapter just refuses to connect to the router. The classmate can connect to the router perfectly fine.
Radio/game adapter on robot not working? RoboGuy Technical Discussion 4 15-04-2010 00:24
cannot connectto cRio with wind river Yuan Xue Lim C/C++ 2 05-02-2010 11:26
Code to communicate with the net book [JAVA] Sean Raia Programming 0 17-01-2010 15:43
RC will not communicate with OI Ryank Electrical 3 08-01-2008 17:00
Cannot force 2004 RC into automode with team number 0 bear24rw Programming 0 07-10-2007 20:42
