Re: CIM motor + Electrical outlet = ?
I don't follow what the point of that would be.
If the circuit breaks at 40 amps, you wouldn't need a AC-DC converter that could output 1600 watts.
A 40 Amp breaker doesn't mean it trips at 40, it can hold currents above that for appreciable amounts of time. |
I have run a CIM from a high quality 500W computer power supply. You need to look at the specs though, as most computer power supplies provide more current on the 5V side than on the 12V side.
Would this work? http://www.harborfreight.com/1500-lb...nch-96127.html
It does vertical motion, but it doesn't do the lateral motion around the pole that I'm looking for. Any motor suggestions, that are just motors, that run off a 120V AC outlet? Thinking of salvaging some household appliance motors like vacuums, or like someone said an HVAC motor if that would work. |
Why don't you separate vertical motion and lateral motion into two separate systems? You could have your TV mounted on a pivot bracket and adjust the angle with a fairly slow but powerful motor, then move the whole assembly up and down with a cable-elevator and winch?
No suggestions on AC motors. You could, however, get a battery enough to power the motors for a decent period of time (e.g. a FIRST battery, but smaller) and hook it up to a charging circuit, so the battery provides the current needed to run the motors and the charger recharges the battery at a slower rate then it is discharged. |
Take a look around at www.surpluscenter.com
#10
I'll keep that in mind, because doing 2 separate systems would be so much easier to actually accomplish. Quote:
#11
http://dvice.com/archives/2010/04/ball-balancing.php So maybe something ball shaped but flexible so it can grip to the pole. What do you recommend as a safety system? |
#13
i want one of these
http://www.youtube.com/watch?v=_i3zfL1VUGo |
#14
Spring loaded rubber grips that lock on the pole? I could probably use a less powerful motor to hold those open and then when the motors stop moving, those could close.
| your thoughts on the FP CIM/2.5 CIM motor drive setup versus 2 2.5 CIM motors | waialua359 | Motors | 11 | 14-12-2007 04:29 |
| CIM motor gearbox | tseres | Motors | 3 | 22-05-2007 22:31 |
| CIM motor on 30A | jason701802 | Motors | 4 | 05-02-2007 20:23 |
| dewalt motor VS. CIM motor | John Gutmann | Motors | 12 | 10-01-2007 18:57 |
| CIM motor components | natis | Motors | 4 | 13-01-2006 11:04 |
