Go to Post Safe zones are for the weak. - ChristopherSD [more]
Unread 16-05-2010, 21:21
IanW's Avatar
IanW IanW is offline
Rookie Mentor
AKA: Ian
FRC #0997 (Spartans)
IanW has a reputation beyond reputeIanW has a reputation beyond reputeIanW has a reputation beyond reputeIanW has a reputation beyond reputeIanW has a reputation beyond reputeIanW has a reputation beyond reputeIanW has a reputation beyond reputeIanW has a reputation beyond reputeIanW has a reputation beyond reputeIanW has a reputation beyond reputeIanW has a reputation beyond repute
pic: 6 Wheel Drive Render 2.0
Unread 16-05-2010, 21:23
Hawiian Cadder's Avatar
Hawiian Cadder Hawiian Cadder is offline
AKA: Isaak
FRC #0159 (Alpine Robotics)
Team Role: CAD
Hawiian Cadder is a name known to allHawiian Cadder is a name known to allHawiian Cadder is a name known to allHawiian Cadder is a name known to allHawiian Cadder is a name known to allHawiian Cadder is a name known to all
Re: pic: 6 Wheel Drive Render 2.0
if there are omni wheels on the sides, why does the center wheel have to be dropped that much, i would go with 1/6 because the omni wheels will wear about the same.
Unread 16-05-2010, 21:40
O'Sancheski O'Sancheski is offline
O'Sancheski has a reputation beyond reputeO'Sancheski has a reputation beyond reputeO'Sancheski has a reputation beyond reputeO'Sancheski has a reputation beyond reputeO'Sancheski has a reputation beyond reputeO'Sancheski has a reputation beyond reputeO'Sancheski has a reputation beyond reputeO'Sancheski has a reputation beyond reputeO'Sancheski has a reputation beyond reputeO'Sancheski has a reputation beyond reputeO'Sancheski has a reputation beyond repute
this one looks much better than your first... i am making a few chassis which i will upload later... who knows, i might see some of these chassis out on the field for next year
Unread 16-05-2010, 21:43
Chris is me's Avatar
AKA: Pinecone
1/8 is less than 1/6.
Wheel drops generally aren't picked because of tread wear.
Unread 17-05-2010, 00:05
Edoc'sil's Avatar
Edoc'sil Edoc'sil is offline
FRC #2531
Rookie Year: 2007
Edoc'sil has a spectacular aura aboutEdoc'sil has a spectacular aura about
If those are andymark wheels you actually have to drop the plaction wheel down 1/8 ish, because even though supposedly the wheels have the same diameter, they really do not.
Sucks if your plactions are not touching the ground.
Here lies a toppled god-
His fall was not a small one.
We did but build his pedestal,
A narrow and a tall one.
Unread 17-05-2010, 17:49
Cyberphil's Avatar
Cyberphil Cyberphil is offline
That Guy
AKA: Phil
FRC #0103 (Cybersonics)
Rookie Year: 2007
Cyberphil has much to be proud ofCyberphil has much to be proud ofCyberphil has much to be proud ofCyberphil has much to be proud ofCyberphil has much to be proud ofCyberphil has much to be proud ofCyberphil has much to be proud ofCyberphil has much to be proud ofCyberphil has much to be proud of
Send a message via AIM to Cyberphil
Are the omnis necessary on this chassis? We have just about the same design with a very small drop in the middle with no omnis at all and it has to be one of the most smooth-driving chassis we have ever had!
Im just wondering.
Unread 17-05-2010, 18:52
joeweber's Avatar
joeweber joeweber is offline
Coach team 1322
FRC #1322 (G.R.A.Y.T. Leviathons)
Team Role: Coach
Rookie Year: 2000
joeweber has a brilliant futurejoeweber has a brilliant futurejoeweber has a brilliant futurejoeweber has a brilliant futurejoeweber has a brilliant futurejoeweber has a brilliant futurejoeweber has a brilliant futurejoeweber has a brilliant futurejoeweber has a brilliant futurejoeweber has a brilliant futurejoeweber has a brilliant future
I would change from four omni wheels to two omni wheels on the opposite corners with standard drive wheels in the other corners. With just two omni wheels in the oposit corners you will have btter traction and you will be able to turn easy. Or if you are droping the center wheels forget the omnis all together.
If your not dirty than you must be just watching.
Thank's to http://weberelectric.biz/
FRC Team sitehttp://team1322.org/
2004 Great Lakes Xerox Creativity Award, 2008 Web Site Excellence Award, 2010 Kettering District and Western Michigan District Excellence in Engineering award, 2011 Kettering District Gracious Professionalism Award. 2011 Ann Arbor and State Cooperation Awards.2013 Kettering Xeroc Creativity Award.2015 Escanaba Chairman's Award.2015 Kettering Spirit Award.2016 Kettering Chairman's Award
FTC Lightining Boltz 5954, Thunder Botz 7032http://team1322.org/vex.htm
Unread 18-05-2010, 10:21
548swimmer's Avatar
548swimmer 548swimmer is offline
CAD Leader
AKA: Alec Wagner
FRC #0548 (Robostangs)
Team Role: CAD
548swimmer has much to be proud of548swimmer has much to be proud of548swimmer has much to be proud of548swimmer has much to be proud of548swimmer has much to be proud of548swimmer has much to be proud of548swimmer has much to be proud of548swimmer has much to be proud of
Won't the traction wheels in the opposite corners cause too much friction to turn assuming all wheels are on the same plane? The point of a rocker is to cause a wheel configuration that is shorter than it is wide. With omni's in opposite corners, you will not have this configuration. This could potentially prevent turning. Prototype it though.
My religion is physics, it can explain everything.
WINNER -- 2011 Waterford District
District Chairman's -- 2011 Waterford District
Finalist -- 2011 Ann Arbor District
State Chairman's -- 2011 Michigan State Championship
Quarter-finalist -- 2011 Galileo
2011 Championship -- Highest Ranking Score
pic: 4 inch Wheel Render Chris is me Extra Discussion 25 15-05-2010 18:43
pic: 6 Wheel Drive Render IanW Extra Discussion 6 08-05-2010 11:39
pic: 6 Wheel Drive Chasis AJ R Extra Discussion 5 06-01-2007 08:49
pic: Jester Drive:Mecanum Wheel Drive Train Ken Delaney 357 Technical Discussion 64 29-03-2006 22:16
pic: Chantilly Academy's 4 Wheel Drive 4 Wheel Steering!!!! jskene Robot Showcase 25 18-02-2005 20:24
