Go to Post It is great to see your friends and other teams succeed. - Bob Steele [more]
Unread 18-05-2010, 07:14
carpenma's Avatar
carpenma carpenma is offline
<-- Ya, FIRST is on my pumpkin
AKA: Matt Carpenter
FRC #0548 (Robostangs)
Team Role: Webmaster
Rookie Year: 2007
carpenma is an unknown quantity at this point
Send a message via AIM to carpenma
pic: Drivetrain Prototype
Unread 18-05-2010, 07:18
ttldomination's Avatar
ttldomination ttldomination is offline
Sunny
Rookie Year: 2007
ttldomination has a reputation beyond reputettldomination has a reputation beyond reputettldomination has a reputation beyond reputettldomination has a reputation beyond reputettldomination has a reputation beyond reputettldomination has a reputation beyond reputettldomination has a reputation beyond reputettldomination has a reputation beyond reputettldomination has a reputation beyond reputettldomination has a reputation beyond reputettldomination has a reputation beyond repute
Re: pic: Drivetrain Prototype
Hm...
What's the diameter of the wheels?
And what is the effective wheel base?
A lot of robotics in '09 were wide based, so this stance might be alright. But some teams took *this* design even further and turned it into a 6WD.
And also, you have a lot of supports, or spacers, running along the top of the chassis, it might also be benefitial to put some support along the bottom.
- Sunny
1648: 2013-2014
5283: 2015
Unread 18-05-2010, 07:28
sgreco's Avatar
sgreco sgreco is offline
AKA: Steven Greco
FRC #2079
Team Role: Mechanical
Rookie Year: 2007
sgreco has a reputation beyond reputesgreco has a reputation beyond reputesgreco has a reputation beyond reputesgreco has a reputation beyond reputesgreco has a reputation beyond reputesgreco has a reputation beyond reputesgreco has a reputation beyond reputesgreco has a reputation beyond reputesgreco has a reputation beyond reputesgreco has a reputation beyond reputesgreco has a reputation beyond repute
Make sure you add some cross supports to the bottom of the two plates. Right now if that thing takes a hit it's going to bend inward.
Your sprockets look large, if you reduce the size of the sprockets both off the gearbox and on the wheel you can save some weight (and space) and keep the same ratio.
Unread 18-05-2010, 09:55
Ian Curtis Ian Curtis is offline
Best Available Data
FRC #1778 (Chill Out!)
Ian Curtis has a reputation beyond reputeIan Curtis has a reputation beyond reputeIan Curtis has a reputation beyond reputeIan Curtis has a reputation beyond reputeIan Curtis has a reputation beyond reputeIan Curtis has a reputation beyond reputeIan Curtis has a reputation beyond reputeIan Curtis has a reputation beyond reputeIan Curtis has a reputation beyond reputeIan Curtis has a reputation beyond reputeIan Curtis has a reputation beyond repute
I'm not particularly qualified to talk about drive chassis durability, so I don't have much to add.
However, I think I can save you some weight on this, or another drive train that you build. Having a pair of sprockets with built in hubs is heavy, and having those extra couple of inches of steel shaft is heavier. What you could do is take an AM hub and attach a pair of sprockets to it, spacing the sprockets with bits of plastic. Then just run enough shaft to cantilever the sprockets and hub.
A top down view would look like = []: () : ()
Where = is shaft, : are spacers, () are sprockets, and [] is the hub. Spaces are only there to prevent them from being turned into smilies.
Does that make sense?
CHILL OUT! | Aero Stability & Control Engineer
Adam Savage's Obsessions (TED Talk) (Part 2)
It is much easier to call someone else a genius than admit to yourself that you are lazy. - Dave Gingery
Unread 18-05-2010, 12:32
EricH's Avatar
EricH EricH is offline
New year, new team
FRC #1197 (Torbots)
You could save a bit more weight without losing much strength by changing all the X patterns into pairs of triangles. Your machinist will also thank you for doing that; fewer cuts means fewer opportunities for something to go haywire and less time before you get the plate back.
Also, I might ramp up the plate thickness a bit around high-stress areas--mounting points and axle attachment areas--or put a flange on, like you would do for sheet metal.
Past teams:
2003-2007: FRC0330 BeachBots
2008: FRC1135 Shmoebotics
Unread 18-05-2010, 18:22
Hawiian Cadder's Avatar
Hawiian Cadder Hawiian Cadder is offline
AKA: Isaak
FRC #0159 (Alpine Robotics)
Team Role: CAD
Hawiian Cadder is a name known to allHawiian Cadder is a name known to allHawiian Cadder is a name known to allHawiian Cadder is a name known to allHawiian Cadder is a name known to allHawiian Cadder is a name known to all
i would recommend against dually P80s. our team has used them in the past and found that they are hard to assemble, as well as grease migrating towards the motors and out of the planetary part of the gearbox. two single P80s would be better in my opinion.
Unread 18-05-2010, 18:24
548swimmer's Avatar
548swimmer 548swimmer is offline
CAD Leader
AKA: Alec Wagner
Team Role: CAD
548swimmer has much to be proud of548swimmer has much to be proud of548swimmer has much to be proud of548swimmer has much to be proud of548swimmer has much to be proud of548swimmer has much to be proud of548swimmer has much to be proud of548swimmer has much to be proud of
Two single p80's per side? Or two total?
Also, we have never had issues with our p80's, though is the first year we have used them.
My religion is physics, it can explain everything.
WINNER -- 2011 Waterford District
District Chairman's -- 2011 Waterford District
Finalist -- 2011 Ann Arbor District
State Chairman's -- 2011 Michigan State Championship
Quarter-finalist -- 2011 Galileo
2011 Championship -- Highest Ranking Score
Unread 18-05-2010, 18:33
sdcantrell56's Avatar
sdcantrell56 sdcantrell56 is offline
AKA: Sean
FRC #2415 (Wired Cats)
sdcantrell56 has a reputation beyond reputesdcantrell56 has a reputation beyond reputesdcantrell56 has a reputation beyond reputesdcantrell56 has a reputation beyond reputesdcantrell56 has a reputation beyond reputesdcantrell56 has a reputation beyond reputesdcantrell56 has a reputation beyond reputesdcantrell56 has a reputation beyond reputesdcantrell56 has a reputation beyond reputesdcantrell56 has a reputation beyond reputesdcantrell56 has a reputation beyond repute
I would shy away from the p80's simply for the fact that the planetary transmissions are less efficient by design and arguably more fragile than standard toughboxes. You can easily buy all the parts necessary for direct drive from andymark as well and direct driving one wheel and chaining to the other would be the most reliable and lightest weight solution.
Mentor 2415
Unread 18-05-2010, 18:46
PAR_WIG1350's Avatar
PAR_WIG1350 PAR_WIG1350 is offline
AKA: Alan Wells
FRC #1350 (Rambots)
PAR_WIG1350 has a reputation beyond reputePAR_WIG1350 has a reputation beyond reputePAR_WIG1350 has a reputation beyond reputePAR_WIG1350 has a reputation beyond reputePAR_WIG1350 has a reputation beyond reputePAR_WIG1350 has a reputation beyond reputePAR_WIG1350 has a reputation beyond reputePAR_WIG1350 has a reputation beyond reputePAR_WIG1350 has a reputation beyond reputePAR_WIG1350 has a reputation beyond reputePAR_WIG1350 has a reputation beyond repute
yup, as long as it's properly tensioned 35 chain.
Unread 18-05-2010, 19:08
548swimmer's Avatar
CAD Leader
AKA: Alec Wagner
Team Role: CAD
I'm not sure why, but we always use 25 chain
Unread 18-05-2010, 19:16
EricH's Avatar
New year, new team
FRC #1197 (Torbots)
25 chain is lighter, but less forgiving than 35 chain.
Past teams:
pic: prototype drivetrain v2.1 548swimmer Extra Discussion 16 11-05-2010 09:05
pic: Prototype Drivetrain v2 548swimmer Extra Discussion 47 11-05-2010 01:13
pic: Prototype Drivetrain 548swimmer Extra Discussion 38 09-05-2010 21:14
pic: 499 Prototype drivetrain final layout Andrew Schuetze Extra Discussion 9 01-01-2008 21:37
pic: A drivetrain prototype idea GMAdan Extra Discussion 16 24-04-2007 16:14
