Go to Post (Don't ask why a retired FIRSTer is on CD, it's a twelve step process kind of thing) - Matt Krass [more]
Unread 20-05-2010, 13:21
JohnFogarty's Avatar
JohnFogarty JohnFogarty is offline
Trapped under a pile of MECANUMS :P
AKA: @doctorfogarty
FTC #11444 (Garnet Squadron) & FRC#1102 (M'Aiken Magic)
JohnFogarty has a reputation beyond reputeJohnFogarty has a reputation beyond reputeJohnFogarty has a reputation beyond reputeJohnFogarty has a reputation beyond reputeJohnFogarty has a reputation beyond reputeJohnFogarty has a reputation beyond reputeJohnFogarty has a reputation beyond reputeJohnFogarty has a reputation beyond reputeJohnFogarty has a reputation beyond reputeJohnFogarty has a reputation beyond reputeJohnFogarty has a reputation beyond repute
FTC Prototype Board IR Break Beam.
So I was wondering if it was possible to make a custom sensor using the prototype board that is like a detector beam. Where when an object is in the line of the beam the signal is tripped, I know this is simple but how do you do it?
John Fogarty
2010 FTC World Championship Winner & 2013-2014 FRC Orlando Regional Winner
Mentor FRC Team 1102 M'Aiken Magic
"Head Bot Coach" FTC Team 11444 Garnet Squadron
Former Student & Mentor FLL 1102, FTC 1102 & FTC 3864, FRC 1772, FRC 5632
2013 FTC World Championship Guest Speaker
Unread 01-06-2010, 23:53
davidthefat davidthefat is offline
Alumni
AKA: David Yoon
FRC #0589 (Falkons)
Rookie Year: 2010
davidthefat has much to be proud ofdavidthefat has much to be proud ofdavidthefat has much to be proud ofdavidthefat has much to be proud ofdavidthefat has much to be proud ofdavidthefat has much to be proud ofdavidthefat has much to be proud ofdavidthefat has much to be proud ofdavidthefat has much to be proud of
Re: FTC Prototype Board IR Break Beam.
our team just got a IR LED thing and a IR detector and lined them up, if the IR detector is not detecting, then the thing is tripped.
Do not say what can or cannot be done, but, instead, say what must be done for the task at hand must be accomplished.
Unread 02-06-2010, 00:34
biojae's Avatar
biojae biojae is offline
Likes Omni drives :)
AKA: Justin Stocking
FTC #5011 (BOT SQUAD) && FTC#72(Garage bots)&& FRC#0399 (Eagle Robotics)
biojae is a jewel in the roughbiojae is a jewel in the roughbiojae is a jewel in the rough
Yes, it is possible to build an IR break beam sensor with the protoboard.
But, there are 2 reasons why it would be illegal for Hot Shot! :
1. The Q&A response for using LEDs as a sensor
Originally Posted by FTC Q&A
A: <R5>d.8 specifically limits LED's to be used only for signaling to the drive team or for decorations. Homebrew light sensors using LED light sources do not fit within the allowed usages of LEDs and are therefore not allowed.
2. The rule restricting it to visible light only
Originally Posted by FTC Rules
<R5> d.8 8. Only visible light LEDs may be connected to the Prototype Board. These visible LEDs may only be used as a cueing signal for the team or for decoration. If used, the purpose must be demonstrated during inspection.
FTC Team 72 - No site
FRC Team 399 - http://www.team399.org
2010 Rockwell Collins Innovation in Control Award - (Use of the CAN bus, among other reasons) Phoenix, Arizona!
[FTC]: Chain Break Andrew Remmers FIRST Tech Challenge 2 18-10-2009 11:34
Break Out Board??? Betty_Krocker FRC Control System 6 10-02-2009 10:26
pic: New FTC robots prototype N7UJJ Extra Discussion 13 09-07-2008 16:02
pic: FTC 35's prototype for 2007 wilsonmw04 Extra Discussion 2 08-11-2007 18:38
pic: 1382 Brazil Prototype + Electronic Board tribotec_ca88 Extra Discussion 1 29-01-2005 15:54
