Re: pic: My First WCD
If all your wheels are in line with each other you will not be able to turn. you need to lower the middle wheel so there are never more then 4 wheels on the ground at a time.
With the holes on the side plate, it looks like you have two holes to press-fit bearings for the center wheels into. This led me to believe that your center wheels were not on the same line in the center of the 'bot. Also, from this render it looks they don't quite line up (again with the two bearing holes). I trust you that they are in the center, but it was just a concern I had at the time.
http://www.chiefdelphi.com/forums/sh...c+968+practice Looks really nice! Any idea on weight or thickness of the metal. Also what kind of transmission/gear ratio is that? |
| pic: WCD Chassis Idea | Rion Atkinson | Extra Discussion | 22 | 21-05-2010 14:17 |
| pic: WCD Sheet Metal Concept Chassis | GarrettF2395 | Extra Discussion | 22 | 20-05-2010 16:33 |
| pic: me (Leav) getting some water while MCing at the first FIRST off season event in Israel. | Leav | Extra Discussion | 3 | 17-12-2007 23:18 |
| pic: FIRST in theyre blood...the first meeting | Rohith Surampudi | Extra Discussion | 14 | 11-11-2006 21:15 |
| pic: My first National FIRST T-shirt Day | CD47-Bot | Extra Discussion | 13 | 07-09-2004 18:50 |
