Go to Post We can read about torque and speed in books, we can build a robot and drive it, but determination and character are built by time and encouragement, not just by studying. - Eugenia Gabrielov [more]
Unread 21-05-2010, 12:50
lior_regev lior_regev is offline
FRC #2630
lior_regev can only hope to improve
question| LabVIEW Multiple comps
Hello,
Is it possible to work on the same LV poject using multiple computers simultaneously?
if it is, how can you do it?
i figured that simply sharing the files over a network would mess things up cuz *.lvproj files won't be synced..
Unread 22-05-2010, 14:54
Re: question| LabVIEW Multiple comps
I can't say that I've tried it. The project tends to lock files as they are opened. I can't say for sure that it will work, but since the project isn't much more than a list of file references, most things should be fine. You may gain further isolation by defining libraries for subsystems.
I'm curious to know what issues you run into.
What we normally do is use a source control system and treat the project as a normal file. Since it is XML you can diff it if needed, but avoid it if you can.
Greg McKaskle
How to track multiple trailers in LabVIEW. Joshamuffin NI LabVIEW 1 02-07-2009 16:57
Multiple Autonomous Codes Question domoarigato Programming 8 11-02-2009 16:26
LabVIEW on multiple computers. Joshamuffin National Instruments LabVIEW and Data Acquisition 2 12-01-2009 15:45
Labview dashboard and multiple variables Joe Ross LabView and Data Acquisition 2 15-03-2006 21:55
Computer with multiple hard drives question. Elgin Clock Technical Discussion 2 03-12-2004 11:41
