Go to Post Without fail, judges always come by when the spokespeople are in the bathroom, so others should be able to cover until they're back. - Jacob Bendicksen [more]
Unread 25-05-2010, 16:27
billbo911's Avatar
billbo911 billbo911 is offline
I prefer you give a perfect effort.
AKA: That's "Mr. Bill"
FRC #2073 (EagleForce)
billbo911 has a reputation beyond reputebillbo911 has a reputation beyond reputebillbo911 has a reputation beyond reputebillbo911 has a reputation beyond reputebillbo911 has a reputation beyond reputebillbo911 has a reputation beyond reputebillbo911 has a reputation beyond reputebillbo911 has a reputation beyond reputebillbo911 has a reputation beyond reputebillbo911 has a reputation beyond reputebillbo911 has a reputation beyond repute
Re: pic: Prototype Drivetrain
Originally Posted by Michael Corsetto View Post
Instead of using washers to lower your middle wheels, try drilling the holes in all 16 pillow blocks off center by 1/16", and flip the middle ones over so the axle ends up being 1/8" lower than the outside axles. Adding washers isn't as clean/sturdy.
Excellent suggestion. Simple and if a jig is used, very repeatable.
Also, to lower your CG (which is ALWAYS important), you might want to mount the pillow blocks on the top side of your lower frame members, that way the whole frame is lowered a total of 2 inches. And try mounting your electronics (Battery/CRio/etc) on the lower frame level, not the upper one. This will lower your CG and give the manipulator teams more area to work with. Win Win.
From my many years in the Medical Imaging field performing maintenance on very heavy mobile systems, I have to disagree here, to a point.
With the pillow blocks on the bottom of the main rails, the axles put the pillow blocks and their mounting hardware in compression. The weight of the robot is transfered to the wheels without being suspended by mounting bolts.
Now, if the pillow blocks were moved to the top of the rails, then the mounting hardware would carry the load to the wheels, thus creating an additional point of failure, unless designed properly, which would add weight.
Now to take this a step further, why use pillow blocks at all?
The OP said these were dead axles. If that is the case, then just mount them directly through the frame. Granted, you will not lower the CG quite as far, but I believe, based on the picture and description, it would be more than sufficient.
CalGames 2009 Autonomous Champion Award winner
Sacramento 2010 Creativity in Design winner, Sacramento 2010 Quarter finalist
2011 Sacramento Finalist, 2011 Madtown Engineering Inspiration Award.
2012 Sacramento Semi-Finals, 2012 Sacramento Innovation in Control Award, 2012 SVR Judges Award.
2012 CalGames Autonomous Challenge Award winner ($$$).
2014 2X Rockwell Automation: Innovation in Control Award (CVR and SAC). Curie Division Gracious Professionalism Award.
2014 Capital City Classic Winner AND Runner Up. Madtown Throwdown: Runner up.
2015 Innovation in Control Award, Sacramento.
2016 Chezy Champs Finalist, 2016 MTTD Finalist
Unread 25-05-2010, 17:11
Garret's Avatar
Garret Garret is offline
Standing on the Shoulders of Giants
AKA: Garret Smalley
FRC #0691 (Hart District Robotics)
Garret has a reputation beyond reputeGarret has a reputation beyond reputeGarret has a reputation beyond reputeGarret has a reputation beyond reputeGarret has a reputation beyond reputeGarret has a reputation beyond reputeGarret has a reputation beyond reputeGarret has a reputation beyond reputeGarret has a reputation beyond reputeGarret has a reputation beyond reputeGarret has a reputation beyond repute
It looks like you only have 2 CIMS powering your drivetrain. Did you do this to save weight, or do you have another purpose for them? I'm of the belief that there are enough motors available in the KOP that 4 CIMs (or at least a CIM and a FP) should be used on any drive train (with 2K9 being an anomaly).
My team uses only two CIMs on our drive train in general so that we free up the rest to use on manipulators. depending on what we plan to do with the robot I may or may not add the additional CIMs.
Replace all the 1/16th wall aluminum with 0.035" wall 4130 steel square tubing. You'll improve chassis strength, stiffness, maintain the same weight, and your welder will have an easier time
The reason I used the materials I did is because my team has a very, very, very low off season budget and all the materials are scrap from this year's robot.
In terms of welding we have a sponsor who will weld our aluminum for us and they really do not have a problem welding it.
Are you using Riv-nuts to hold on the axle pillow blocks?
We are using 1/4-20 bolts and nylock nuts. I just didn't drill the holes because Inventor crashed.
Instead of using washers to lower your middle wheels, try drilling the holes in all 16 pillow blocks off center by 1/16", and flip the middle ones over so the axel ends up being 1/8" lower than the outside axels. Adding washers isn't as clean/sturdy.
I would not have thought of drilling holes off center. In general we have used washers and other spacers because we really don't have access to precision machine tools due to the fact we build out of one of the team members garages.
The battery, compressor, and speed controllers are all below the top of the frame, I put the CRIO on top for easier access. There will be a cover over it. I left the front Area pretty open and thought that that was enough space for the manipulators.
whereas welded 6061 aluminum will be total garbage, around 8-10KSI.
I have never had an aluminum weld break on me. We also use a professional welder on our frame.
How strong are the brunner connectors and 80/20 quickframe system. How much do they cost?
I appreciate the suggestions greatly and will try to implement them where possible.
Unread 25-05-2010, 18:08
Chris is me's Avatar
AKA: Pinecone
What gear ratio are you running in the Toughbox, and what's your chain reduction?
Unread 26-05-2010, 07:51
camtunkpa camtunkpa is offline
it's like shooting fish in a barrel
AKA: Cliff Mock
FRC #0222 (Tigertrons)
Rookie Year: 1997
camtunkpa has a reputation beyond reputecamtunkpa has a reputation beyond reputecamtunkpa has a reputation beyond reputecamtunkpa has a reputation beyond reputecamtunkpa has a reputation beyond reputecamtunkpa has a reputation beyond reputecamtunkpa has a reputation beyond reputecamtunkpa has a reputation beyond reputecamtunkpa has a reputation beyond reputecamtunkpa has a reputation beyond reputecamtunkpa has a reputation beyond repute
The 80/20 quickframe is fairly rigid when you tie everything together. out of the 3 years we've used quickframe we've never had a failed corner connector or had our frame come apart. The biggest selling point for us is being able to build a robot frame extremely quickly. Price wise the quickframe can be found for about $10 for 8' and corner connectors are like $2.60 a piece. Price can vary depending on your local 80/20 dealer we tend to get our stuff from the 80/20 garage sale ebay store because of availability.
Good luck with your prototype!
"Engineering is making the impossible happen"
"We are here to create, not merely survive" - unknown fortune cookie
"If you don't push the envelope you're just spinning your wheels"
Unread 25-05-2010, 16:36
548swimmer's Avatar
548swimmer 548swimmer is offline
CAD Leader
AKA: Alec Wagner
FRC #0548 (Robostangs)
Team Role: CAD
548swimmer has much to be proud of548swimmer has much to be proud of548swimmer has much to be proud of548swimmer has much to be proud of548swimmer has much to be proud of548swimmer has much to be proud of548swimmer has much to be proud of548swimmer has much to be proud of
I'm not sure if I just missed, but what's the total weight?
Have you considered using sheet metal/lexan for your outermost part?
What about tensioners for your chain/belt?
My religion is physics, it can explain everything.
WINNER -- 2011 Waterford District
District Chairman's -- 2011 Waterford District
Finalist -- 2011 Ann Arbor District
State Chairman's -- 2011 Michigan State Championship
Quarter-finalist -- 2011 Galileo
2011 Championship -- Highest Ranking Score
Unread 25-05-2010, 17:19
Garret's Avatar
AKA: Garret Smalley
I did not notice this post while I writing my response.
What is shown wieghs about 48 lbs.
What do you mean by using sheet metal and lexan for the outermost part.
I wanted to put tensioners in but my 5 year old DELL laptop could barely run inventor long enough to make this render.
I would like suggestions on how to implement tensioners though.
Unread 25-05-2010, 19:21
548swimmer's Avatar
CAD Leader
AKA: Alec Wagner
Team Role: CAD
48 lbs seems a touch on the heavy side. Is the battery included?
Instead of using tube stock for your outside frame, can you replace them with bolted on sheet metal?
What we do is two pieces of nylon bolted through a spacing tube, and to tighten them we just tighten the bolts down, to loosen we loosen them.
pic: Drivetrain Prototype carpenma Extra Discussion 28 19-05-2010 21:53
pic: prototype drivetrain v2.1 548swimmer Extra Discussion 16 11-05-2010 09:05
pic: Prototype Drivetrain v2 548swimmer Extra Discussion 47 11-05-2010 01:13
pic: Prototype Drivetrain 548swimmer Extra Discussion 38 09-05-2010 21:14
pic: A drivetrain prototype idea GMAdan Extra Discussion 16 24-04-2007 16:14
