cRIO isolation pads?
We just received our new cRIO-FRC from NI, and it came with some adhesive-backed pads. They had holes in them that fit around some of the ports on the cRIO chassis (e.g. the two ethernet holes, the power connector, serial port, and indicator light). However, they only fit correctly around the ports when the pad is turned upside down, with the adhesive facing up around the chassis. How are these pads supposed to be used? What function do they serve?
Re: cRIO isolation pads?
Do they look like these? http://www.andymark.biz/am-0590.html
Directions are posted by NI here:
How Do I Clean My cRIO-FRC and Install Protective Gaskets? They keep metal dust and shards out of the cRIO electronics. Quite a lot pile up inside the chassis over a season mounted within a robot. Drilling, filing, gears grinding, metal rubbing, all produce debris that works it's way into the cRIO. Those gaskets seal around the most obvious openings. Last edited by Mark McLeod : 25-05-2010 at 21:19. |
Have there been any failures from this sort of thing?
Aha! My coach and I both assumed that the gaskets were for the outside of the cRIO, this makes it clear that they are instead for the inside. Thanks for the help!
Greg McKaskle |
| Vibration Isolation Mounts | Free Willy | Pneumatics | 10 | 19-02-2010 07:40 |
| Balancing Pads | ROFLcopter | Rules/Strategy | 5 | 15-02-2009 19:39 |
| chassis isolation, contrary to UL1740? | grambo | Electrical | 10 | 18-10-2008 20:18 |
| Pressure Pads | Deltafrog | Rules/Strategy | 6 | 09-01-2005 00:27 |
| Knee Pads | kjohnson | Rules/Strategy | 6 | 09-02-2004 22:05 |
