Go to Post Holy mechanum wheels Batman! - yodameister [more]
Unread 29-05-2010, 23:25
Monkeysaur Monkeysaur is offline
Rookie Year: 2010
Monkeysaur is an unknown quantity at this point
Joystick Compatibility with LabVIEW
My team is about to purchase a new 3-D Joystick for our Mecanum bot chassis and we were wondering if this joystick is legal and compatible with the labview framework.
The joystick is the Logitech 3D Pro Joystick - link here.
Thank you!
Unread 29-05-2010, 23:50
Radical Pi Radical Pi is offline
Putting the Jumper in the Bumper
AKA: Ian Thompson
FRC #0639 (Code Red Robotics)
Rookie Year: 2010
Radical Pi has a spectacular aura aboutRadical Pi has a spectacular aura aboutRadical Pi has a spectacular aura about
Re: Joystick Compatibility with LabVIEW
Any joystick that windows can recognize as a joystick (which is almost all of them) will be able to run with the FRC driver station. As long as the proper drivers are installed on the classmate (or whatever computer you are using if this is out of competition), it should run (all of the handling is done DS-side, the robot just gets data from the DS)
And yes it is legal (any USB-based device is allowable by the rules)
"To have no errors would be life without meaning. No strugle, no joy"
"A network is only as strong as it's weakest linksys"
Unread 30-05-2010, 07:17
rwood359 rwood359 is offline
AKA: Randy
FRC #0359 (Hawaiian Kids)
rwood359 is a name known to allrwood359 is a name known to allrwood359 is a name known to allrwood359 is a name known to allrwood359 is a name known to allrwood359 is a name known to all
We tested that one last year. It works fine.
Saitek X52 Joystick Compatibility Patrick Chiang NI LabVIEW 1 14-01-2010 20:06
joystick axis in labview frcchile NI LabVIEW 7 20-02-2009 12:06
Labview Joystick Buttons... team877 NI LabVIEW 36 17-02-2009 19:23
labview:what is the joystick axis? mcristina444 NI LabVIEW 4 08-02-2009 13:26
CH Flight Stick Compatibility with 2009 System? programmr Programming 23 17-12-2008 17:14
