Go to Post Excited and motivated students and teachers can do amazing things. - Wetzel [more]
Unread 31-05-2010, 19:07
Robototes2412's Avatar
Robototes2412 Robototes2412 is offline
1 * 4 != 14
FRC #2412 (Robototes)
Rookie Year: 2007
Robototes2412 is on a distinguished road
H4x0rs needed
Hello,
I am currently in the pre-pre-pre-alpha-alpha stage of getting a working LOLCODE interpreter on a FRC Robot.
Could one of you please take a look at the attatched TGZ and see how hard it would be to hack in a basic WPI library?
It follows the LOLCODE 1.2 spec, but it has objects (bukkits) and less strict typing (if at all). I also added PWNZ OF (>) and OWNZ OF (<) to make programmin' a lot easier.
Thanks
Unread 31-05-2010, 19:13
1 * 4 != 14
Rookie Year: 2007
Re: H4x0rs needed
Weeird, my tgz was 0.0001 kb too big, lol
Unread 31-05-2010, 19:24
Tanner's Avatar
Tanner Tanner is offline
FRC #1261 (Roblions)
Rookie Year: 2007
Tanner is a splendid one to beholdTanner is a splendid one to beholdTanner is a splendid one to beholdTanner is a splendid one to beholdTanner is a splendid one to beholdTanner is a splendid one to behold
Re: H4x0rs needed
I find this pretty funny and find it an interesting project for FIRST. Subject was a bit misleading though.
Gotta love those cats. Will have to see how it runs later.
-Tanner
Unread 31-05-2010, 20:56
Radical Pi Radical Pi is offline
Putting the Jumper in the Bumper
AKA: Ian Thompson
FRC #0639 (Code Red Robotics)
Rookie Year: 2010
Radical Pi has a spectacular aura aboutRadical Pi has a spectacular aura aboutRadical Pi has a spectacular aura about
Re: H4x0rs needed
Well so far it has all of the LOLCODE spec. From this point on I would leave those files alone and make use of the I CAN HAZ command. Example:
Code:
I CAN HAZ WPILIB 2010
That would activate an extension (hooks onto the bottom of the main parser function) which parses for commands that you created. Then you can keep legacy support for changes to WPILib.
Here's the kind of thing I see in the WPILib extension:
Code:
HOW DUZ CONSTRUCT
I SEE THAT JAGUAR ON PORT <port>
I SEE THAT ENCODER ON PORT <port>
I SEE THAT COMPRESSOR ON PORTS <spike port> AND <switch port>
I SEE THAT JOYSTICK ON PORT <port>
IF U SAY SO
HOW DUZ TELEOP
JAGUAR <port> GO <some NUMBAR value>
ENCODER <port> GIMMEH <input variable>
JOYSTICK <port> GIMMEH <input variable>
IF U SAY SO
And so on.
"To have no errors would be life without meaning. No strugle, no joy"
"A network is only as strong as it's weakest linksys"
davidthefat davidthefat is offline
Alumni
AKA: David Yoon
FRC #0589 (Falkons)
Rookie Year: 2010
davidthefat has much to be proud ofdavidthefat has much to be proud ofdavidthefat has much to be proud ofdavidthefat has much to be proud ofdavidthefat has much to be proud ofdavidthefat has much to be proud ofdavidthefat has much to be proud ofdavidthefat has much to be proud ofdavidthefat has much to be proud of
Re: H4x0rs needed
IDK, brain$@#$@#$@#$@# sounds like a better thing to try to interprete
Do not say what can or cannot be done, but, instead, say what must be done for the task at hand must be accomplished.
Unread 31-05-2010, 20:58
pSYeNCe's Avatar
pSYeNCe pSYeNCe is offline
Programaster
AKA: James
FRC #2010 (Lightning Bots)
Rookie Year: 2007
pSYeNCe is a splendid one to beholdpSYeNCe is a splendid one to beholdpSYeNCe is a splendid one to beholdpSYeNCe is a splendid one to beholdpSYeNCe is a splendid one to beholdpSYeNCe is a splendid one to beholdpSYeNCe is a splendid one to behold
Re: H4x0rs needed
Someone posted this in-season as a joke... hopefully if you are actually doing it you'll be met with success I'll program in that.
"Great minds discuss ideas; average minds discuss events; small minds discuss people."
-Eleanor Roosevelt
Unread 01-06-2010, 17:22
1 * 4 != 14
Rookie Year: 2007
Re: H4x0rs needed
I am as serious as the following text is bolded:
YA RLY
and the code would be at the LOLCODE 1.2 spec (with bukkits and P/OWNZ OF) ex:
Code:
O HAI IM ROBOT
 HOW DUZ I NERF YR BEERZ?
  FOUND YR DIFF OF BEERZ AN 1
 IF U SAY SO
KTHX
HAI 1.2
 CAN HAS STDIO?
 I HAS A FOOL ITZ LIEK A ROBOT
 FOOL!!NERF 2
 VISIBLE IT
KTHXBYE
I am working with the author of this lolcode parser (http://www.icanhaslolcode.org) to do this, and we kinda need a zip of the c/++ api (I programmed my team's robot in Java), so if you can provide that, please do .
Peace and Long Life
Unread 01-06-2010, 20:29
rahilm's Avatar
rahilm rahilm is offline
AKA: Rahil Mehta
FRC #0668 (The Apes of Wrath)
Rookie Year: 2007
rahilm has a spectacular aura aboutrahilm has a spectacular aura about
Re: H4x0rs needed
http://first.wpi.edu/Images/CMS/Firs...ce20100107.zip
From the WPILib website
Team 668 - Apes of Wrath - 2008-2011
Team 668 - Apes of Wrath - 2011-Present (Mentor)
Unread 02-06-2010, 01:11
1 * 4 != 14
Rookie Year: 2007
Re: H4x0rs needed
Thank you <3
Does anyone know how to fedangle GCC into outputting a VXWORKS binary?
How about STDIN on the cRIO?
Unread 02-06-2010, 20:37
AKA: Ian Thompson
Rookie Year: 2010
Re: H4x0rs needed
Thank you <3
The easiest way would be to just use Wind River to build it (it uses GCC also). That way you get the header files
And I believe fopen works on the cRIO if you include the right files
Unread 03-06-2010, 18:24
1 * 4 != 14
Rookie Year: 2007
Re: H4x0rs needed
I run Linux, Wind River does not.
Unread 03-06-2010, 21:07
byteit101's Avatar
byteit101 byteit101 is offline
WPILib maintainer (WPI)
AKA: Patrick Plenefisch
no team (The Cat Attack (Formerly))
byteit101 is a glorious beacon of lightbyteit101 is a glorious beacon of lightbyteit101 is a glorious beacon of lightbyteit101 is a glorious beacon of lightbyteit101 is a glorious beacon of lightbyteit101 is a glorious beacon of light
Re: H4x0rs needed
But, wine+makefiles==(WindRiver-IDE)
The attached makefile & utils is from AustinSchuh:
I have a couple scripts and patches that I've collected up that let me build WPILib and pull down the latest.
My makefile pulls down the latest WPILib (you need to point it to the latest version when that changes), patches it (I found a bug, and the makefile needs to get swapped out for it to build), pulls down the latest GCC compiler that is needed to compile for the cRIO, and then builds the code. So, once all the pieces are found and together, it works like a charm.
If I'm doing things right, and you have all the unlisted prerequisites, all you should have to do is type make in the MainRobot directory. And then wait. Make sure you have wput, ftp, and wine, to start with.
The paths might not seem to make the most sense now, but I'm pulling things from our repository and this is how things are set up.
Type make to build the code
Type make deploy to deploy the code. You will have to edit the makefile to change all IP addresses from 10.9.71.2 to your team number.
And that's it. If you want to add more source files, add them on the line that goes something like MainRobot.o.
Once you are that far, you can start poking at it a bit more. It's definately not the most polished makefile in existence.
Bubble Wrap: programmers rewards
Watchdog.Kill();
printf("Watchdog is Dead, Celebrate!");
How to make a self aware robot: while (∞) cout<<(sqrt(-∞)/-0);
Previously FRC 451 (The Cat Attack)
Now part of the class of 2016 at WPI & helping on WPILib
Help Needed. Mars FIRST Lego League 3 30-12-2007 14:03
Volunteers needed! KathieK FIRST Tech Challenge 0 01-11-2006 21:12
Help needed.... Pin Man General Forum 9 02-06-2003 20:40
videos needed archiver 1999 3 23-06-2002 22:09
VIDEO NEEDED archiver 2000 0 23-06-2002 22:07
