Go to Post Just as you and your team will make hard decisions as you struggle to build a robot, FIRST has had to make hard decisions concerning maximizing safety while making the number of rules as small as possible. - Mike Betts [more]
Unread 01-06-2010, 14:25
3286's Avatar
3286 3286 is offline
AKA: mike s
FRC #3286 (the Rock-It surgeons)
Team Role: Teacher
3286 has much to be proud of3286 has much to be proud of3286 has much to be proud of3286 has much to be proud of3286 has much to be proud of3286 has much to be proud of3286 has much to be proud of3286 has much to be proud of3286 has much to be proud of
need sample code for a 4 motor drive system
I have searched, perhaps I did not use the best search parameters. We are off season now and for part of our summer school program I would like to let the students have some time experimenting with the various aspects of Labview. We are going to use our existing code and simply copy and paste it for students to be able to modify it and work with it.
I am looking for code that is arcade style drive, for a 4 motor/ 4 jag system. If it were to have the pneumatic system as well that would be great.
Thanks in advance,
Mike
Unread 01-06-2010, 15:11
Alan Anderson's Avatar
Software Architect
FRC #0045 (TechnoKats)
Re: need sample code for a 4 motor drive system
Start with the default project. Look in the Begin VI. To change it from 2-motor arcade drive to 4-motor arcade drive, all you need to do is replace the 2-motor Open VI with a 4-motor Open VI.
Unread 01-06-2010, 19:22
3286's Avatar
AKA: mike s
Team Role: Teacher
Thanks Alan,
We browsed and searched here at Chief Delphi and I believe one student looked in the Labview examples but to be honest I have let them do the research until this point. We will try this, hopefully it wont be any more difficult than it reads.
Mike
2992 with 5 motor 2011 Prototype Drive System 45Auto General Forum 4 22-04-2010 23:01
Team 3132 - Sample code for writing to a file on the cRIO SteveGarward C/C++ 0 05-02-2010 07:26
Programming Help- 2 Motor 2 joystick Drive System OMAR_567 Programming 2 02-02-2008 14:08
Sample Scoring System program. PhilBot General Forum 0 08-01-2008 09:50
Direct Drive Four Motor System Collin Fultz Technical Discussion 42 02-11-2006 12:03
