Go to Post Who says engineers can't be poets? - Wayne TenBrink [more]
View Poll Results: Does your team use Java or C++ for programming your robot?
Java 35 51.47%
C++ 33 48.53%
Voters: 68. You may not vote on this poll
Unread 01-06-2010, 21:01
LavaEagle LavaEagle is offline
FRC #2660
LavaEagle is an unknown quantity at this point
Java VS C++ || The Final Decision
Which does your team use, Java or C++?
I have searched through these forums and google for this answer and it is very wishy washy.
If you want leave why you use it but vote for either.
Unread 01-06-2010, 21:09
EricH's Avatar
EricH EricH is offline
New year, new team
FRC #1197 (Torbots)
Re: Java VS C++ || The Final Decision
You forgot Labview.
(I'm not on a team, except as an alum, so I can't answer... but I would guess that you'll get a pretty even split between the three.)
Past teams:
2003-2007: FRC0330 BeachBots
2008: FRC1135 Shmoebotics
Unread 01-06-2010, 21:20
Azores's Avatar
Azores Azores is offline
AKA: Andrew
FRC #3161 (Tronic Titans)
Rookie Year: 2010
Azores has a spectacular aura aboutAzores has a spectacular aura aboutAzores has a spectacular aura about
Java. Our school teaches Computer Science in Java, so naturally the programming team liked the idea of using Java to program the robot, since we didn't already have a base in Labview or C++ anyway (2010 team). Though I ended up being the only programmer in the end... so Java definitely was a good choice because I'd hate to be programming a robot solo in a language I'm not already familiar with.
3161 Software Mentor + Photographer
Unread 01-06-2010, 21:22
Radical Pi Radical Pi is offline
Putting the Jumper in the Bumper
AKA: Ian Thompson
FRC #0639 (Code Red Robotics)
Rookie Year: 2010
Radical Pi has a spectacular aura aboutRadical Pi has a spectacular aura aboutRadical Pi has a spectacular aura about
C++. We've had 2 new programmers doing all of the work since the new control system came out and we're both already competent in C++, so we stick with that
"To have no errors would be life without meaning. No strugle, no joy"
"A network is only as strong as it's weakest linksys"
Unread 01-06-2010, 21:34
FRC #2660
LabVIEW is an irrelevant language here!
Unread 01-06-2010, 21:36
davidthefat davidthefat is offline
Alumni
AKA: David Yoon
FRC #0589 (Falkons)
Rookie Year: 2010
davidthefat has much to be proud ofdavidthefat has much to be proud ofdavidthefat has much to be proud ofdavidthefat has much to be proud ofdavidthefat has much to be proud ofdavidthefat has much to be proud ofdavidthefat has much to be proud ofdavidthefat has much to be proud ofdavidthefat has much to be proud of
C++ I find Java to be a language that is similar to C++ but with traning wheels
Do not say what can or cannot be done, but, instead, say what must be done for the task at hand must be accomplished.
Unread 01-06-2010, 22:10
apalrd's Avatar
apalrd apalrd is offline
More Torque!
VRC #3333
If I had to choose between C++ and Java, I would choose C++ for robot programming:
1. The gigantic advantage Java has over C++ is that it can make pretty GUI's. However, that is completely useless in cRio programming as there is no GUI interface.
2. This year, Java was on its first year and C++ was on its second, however the old control system has been using C since 2004. C/C++ is much more proven and tested in FRC robotics as of now then Java.
3. I already know C++. I don't already know Java. I also know and like LabVIEW.
Kettering Motorsports
Unread 01-06-2010, 22:44
FRC #2660
Originally Posted by apalrd View Post
If I had to choose between C++ and Java, I would choose C++ for robot programming....
You sir make a very good point.
Unread 02-06-2010, 00:06
timothyb89 timothyb89 is offline
code monkey
FRC #1977 (Loveland High Robotics)
timothyb89 will become famous soon enough
1. Trust me when I say that Java is *much* more capable than that. Desktop Java, as in version 1.6 with standard libraries is considerably more capable than vanilla C++. Even with the limited version you get on the cRIO (Java 1.3 with J2ME libraries) you can still do plenty. I have plenty of examples if you'd like .
2. With a new and different environment (the cRIO) you can hardly call it 'proven'. The (completely) new C libraries only have a year's head start on their Java equivalent, and having used both, I can say that both work very well.
3. A valid point, but I'd certainly recommend you give it a try- in most cases the syntax is identical or even simpler than a C/++ equivalent so the learning curve is actually quite small.
Originally Posted by Alan Anderson
So is the provided FRC dashboard application.
That doesn't make it good. Trust me when I say that's one of the most inefficient programs I've seen in a long time. I honestly feel bad for the processor on our XO laptop while it (the dashboard) is running- the CPU usage shoots up to 100% rendering something that should barely take any CPU at all.
My opinion on LabVIEW: It may make coding convenient or easy, but that doesn't make it better than other tools.
FRC-DB: A detailed, web-based scouting database for FRC teams with lots of interesting statistics.
Unread 01-06-2010, 22:00
kgzak's Avatar
kgzak kgzak is offline
AKA: Kris
FRC #4392 (Decievers) FRC #2075 (Enigma)
kgzak is a splendid one to beholdkgzak is a splendid one to beholdkgzak is a splendid one to beholdkgzak is a splendid one to beholdkgzak is a splendid one to beholdkgzak is a splendid one to beholdkgzak is a splendid one to behold
How is it irrelevant? It is a programing language with the same, if not more potential than the other programing languages. Our team uses LabView.
Unread 01-06-2010, 23:11
Alan Anderson's Avatar
Software Architect
FRC #0045 (TechnoKats)
The makers of the cRIO would probably disagree about that. The FPGA (the part that does all the "real work") is programmed using LabVIEW. So is the provided FRC dashboard application.
For what it's worth, Team 45 uses neither C++ nor Java.
Unread 01-06-2010, 23:23
FRC #2660
I apologize for disregarding LabVIEW. Wasn't my focus.
Unread 02-06-2010, 00:15
biojae's Avatar
biojae biojae is offline
Likes Omni drives :)
AKA: Justin Stocking
FTC #5011 (BOT SQUAD) && FTC#72(Garage bots)&& FRC#0399 (Eagle Robotics)
biojae is a jewel in the roughbiojae is a jewel in the roughbiojae is a jewel in the rough
As much as I like C++, Netbeans was an easier IDE to use.
Some of the things that made it easier were:
- Integrated Netconsole, Serial comms without a long cord, (connecting to the remote server never worked for us)
- Automatic reboot on download, when not using the debug mode, this saved lots of time
- Automatic file uploader, uploads the correct program file without going to a configuration page even when changing projects
Though, it seemed that there was a memory leak somewhere which would limit us in how many times we could upload / minutes open before we would have to restart netbeans.
And library support was a little lacking this year.
Only the vision libraries that were needed to get the vision tracking were ported.
To access any other parts of the NIvision libraries, JNA (Java Native Access) was required, (Writing a method in C++, compiling it in windriver, and then uploading it)
CAN support for the closed loop modes (current, position, speed) for java was the last language implemented, with a gap between Labview and C++.
But, even without all of the libraries, Java was perfectly capable language for programming the cRIO, and FRC robots.
FTC Team 72 - No site
FRC Team 399 - http://www.team399.org
2010 Rockwell Collins Innovation in Control Award - (Use of the CAN bus, among other reasons) Phoenix, Arizona!
Unread 02-06-2010, 00:42
AustinSchuh AustinSchuh is offline
FRC #0971 (Spartan Robotics) #254 (The Cheesy Poofs)
Rookie Year: 1999
AustinSchuh has a reputation beyond reputeAustinSchuh has a reputation beyond reputeAustinSchuh has a reputation beyond reputeAustinSchuh has a reputation beyond reputeAustinSchuh has a reputation beyond reputeAustinSchuh has a reputation beyond reputeAustinSchuh has a reputation beyond reputeAustinSchuh has a reputation beyond reputeAustinSchuh has a reputation beyond reputeAustinSchuh has a reputation beyond reputeAustinSchuh has a reputation beyond repute
My biggest complaint with Java on the cRIO is that they ported a non-realtime version of Java, instead of a realtime version.
  #15   Spotlight this post!
Unread 02-06-2010, 01:18
Robototes2412's Avatar
Robototes2412 Robototes2412 is offline
1 * 4 != 14
FRC #2412 (Robototes)
Rookie Year: 2007
Robototes2412 is on a distinguished road
I would be overjoyed to use C++ for robot programming,
IF THEY TOOK THE TIME TO MAKE IT COMPILABLE FROM LINUX, FOR THE LOVE OF CHRIST ITS GCC
edit:
Wow, i was angry.
could someone please <code> a makeFile from the C++ stuff? I think I can get C++ working on linux if i have a makefile.
Dean Kamen wrestles with decision: should he quit the Segway? Leon Machado IV FIRST In the News... 4 13-01-2009 16:07
Worst Decision of the Week! JJMax7 General Forum 44 08-03-2006 00:49
The decision of indecision on FIRST's part. cdawzrd General Forum 14 18-01-2005 21:41
pic: The First Big Decision CD47-Bot Extra Discussion 3 10-05-2004 17:57
pic: The final...final match CD47-Bot Extra Discussion 4 17-04-2003 16:24
