Go to Post Who knew there were this many FRC teams that are teams! Very impressive, I might add. - [more]
Unread 08-06-2010, 04:00
R.C.'s Avatar
R.C. R.C. is offline
2017... Oooh Kill em, Swerve!
AKA: Owner, WestCoast Products
FRC #1323 (MadTown Robotics)
R.C. has a reputation beyond reputeR.C. has a reputation beyond reputeR.C. has a reputation beyond reputeR.C. has a reputation beyond reputeR.C. has a reputation beyond reputeR.C. has a reputation beyond reputeR.C. has a reputation beyond reputeR.C. has a reputation beyond reputeR.C. has a reputation beyond reputeR.C. has a reputation beyond reputeR.C. has a reputation beyond repute
CNC Laser
Hey CD,
Our team was looking at purchasing a CNC laser for FRC use. Any suggestions? Our main goal is to cut plastic and aluminum up to about .375" thick.
Thanks,
-RC
R.C.
Owner, WestCoast Products || Twitter
MadTown Robotics Team 1323
Unread 08-06-2010, 08:58
JamesCH95's Avatar
JamesCH95 JamesCH95 is offline
Hardcore Dork
AKA: JCH
FRC #0095 (The Grasshoppers)
JamesCH95 has a reputation beyond reputeJamesCH95 has a reputation beyond reputeJamesCH95 has a reputation beyond reputeJamesCH95 has a reputation beyond reputeJamesCH95 has a reputation beyond reputeJamesCH95 has a reputation beyond reputeJamesCH95 has a reputation beyond reputeJamesCH95 has a reputation beyond reputeJamesCH95 has a reputation beyond reputeJamesCH95 has a reputation beyond reputeJamesCH95 has a reputation beyond repute
Re: CNC Laser
What is your budget?
What size sheets do you want to cut?
What electrical power is available in your shop?
Does it have to be a laser?
Theory is a nice place, I'd like to go there one day, I hear everything works there.
Maturity is knowing you were an idiot, common sense is trying to not be an idiot, wisdom is knowing that you will still be an idiot.
Unread 08-06-2010, 15:32
artdutra04's Avatar
artdutra04 artdutra04 is offline
VEX Robotics Engineer
AKA: Arthur Dutra IV; NERD #18
FRC #0148 (Robowranglers)
artdutra04 has a reputation beyond reputeartdutra04 has a reputation beyond reputeartdutra04 has a reputation beyond reputeartdutra04 has a reputation beyond reputeartdutra04 has a reputation beyond reputeartdutra04 has a reputation beyond reputeartdutra04 has a reputation beyond reputeartdutra04 has a reputation beyond reputeartdutra04 has a reputation beyond reputeartdutra04 has a reputation beyond reputeartdutra04 has a reputation beyond repute
Re: CNC Laser
Originally Posted by R.C. View Post
Hey CD,
Thanks,
-RC
Plastic and aluminum? That will be very expensive to buy one which does both.
My college recently bought a 60 Watt laser cutter for upwards of $15k, and it could barely cut .250 Delrin or .375 acrylic. Don't even think of being able to cut aluminum, it has a hard enough time just engraving color anodized aluminum. Unless you want to shell out massive amounts of money, most institutional-grade laser cutters are designed for large amounts of prototyping, primarily with acrylic.
Art Dutra IV
Robotics Engineer, VEX Robotics, Inc., a subsidiary of Innovation First International (IFI)
Robowranglers Team 148 | GUS Robotics Team 228 (Alumni) | Rho Beta Epsilon (Alumni) | @arthurdutra
世上无难事,只怕有心人.
Unread 08-06-2010, 21:27
DonRotolo's Avatar
Back to humble
FRC #0832
Re: CNC Laser
You really need to decide what the machine's capabilities must be, and then select a design.
Just like building a FRC robot.
Once you know what capabilities you need, contact a manufacturer and let THEM help you determine what machine you need to fulfill those requirements. They can also help you make intelligent choices when you need to compromise - once you see the prices, you'll understand what I mean.
Unread 09-06-2010, 02:14
R.C.'s Avatar
Re: CNC Laser
Clearly I have no clue about how expensive lasers are. Art, we have a router that can currently cut plastic very easily. I really just wanna cut aluminum. What is the price to thickness ratio for laser's that can cut aluminum?
Any recommended models or manufacturers to look at?
Thanks,
-RC
R.C.
Unread 09-06-2010, 04:52
artdutra04's Avatar
Re: CNC Laser
Thanks,
-RC
Other than working with our small campus laser cutter/engraver, I haven't really done any work on/with higher wattage laser cutting machines. However, most of the laser cutting machines designed to cut metal (1000+ Watts) are designed for sheet metal shops in mind. Thus they are physically huge, as they are designed around accommodating 4'x8' sheets of metal. I don't know of any "intermediate" laser cutters between the primarily-plastic prototyping laser cutters and the huge industrial laser cutters.
A quick eBay search found a used one (69,039 hours, or in other words almost eight full years if it ran 24/7/365) for less than $20k, but at 16,660 pounds this isn't something that can be easily moved into a school environment.
Art Dutra IV
世上无难事,只怕有心人.
Unread 09-06-2010, 08:34
sdcantrell56's Avatar
sdcantrell56 sdcantrell56 is offline
AKA: Sean
FRC #2415 (Wired Cats)
sdcantrell56 has a reputation beyond reputesdcantrell56 has a reputation beyond reputesdcantrell56 has a reputation beyond reputesdcantrell56 has a reputation beyond reputesdcantrell56 has a reputation beyond reputesdcantrell56 has a reputation beyond reputesdcantrell56 has a reputation beyond reputesdcantrell56 has a reputation beyond reputesdcantrell56 has a reputation beyond reputesdcantrell56 has a reputation beyond reputesdcantrell56 has a reputation beyond repute
Re: CNC Laser
I am by no means an expert however I believe a laser capable of aluminum in any measurable thickness would be over $100,000 and probably even closer to $150,000. Lasers really don't do well with aluminum even extremely powerful ones with anything thicker than about 1/4"
You could look into a hi-def plasma which would be a great deal cheaper (~50-75k) and still perform well or maybe just forget the idea altogether and get a production mill.
While Im thinking about it I bet you could get a smaller waterjet for much less than a laser. Check out Omax machines
Mentor 2415
Unread 09-06-2010, 12:08
Cory's Avatar
Cory Cory is offline
AKA: Cory McBride
FRC #0254 (The Cheesy Poofs)
Re: CNC Laser
a 5x5 waterjet is around $100-150k last I checked, depending on options
2001-2004: Team 100
2006-Present: Team 254
Unread 09-06-2010, 12:36
JamesCH95's Avatar
Hardcore Dork
AKA: JCH
Re: CNC Laser
I should add that the vo-tech center at my old HS built a workable CNC plasma cutter (5'x9' IIRC) with a donated torch and power supply for about $4500 including a computer and software. It was a very fun project (I designed and machined the stepper motor transmissions) and the machine still works great 5 years later.
Edit: Found this article from Torchmate: http://www.plasma-cutter.com/comparison.htm it compares plasma, hi-def plasma, and laser.
Unread 09-06-2010, 08:44
JamesCH95's Avatar
Hardcore Dork
AKA: JCH
Re: CNC Laser
Thanks,
-RC
If you already have a CNC router that can cut plastic you could consider getting a plasma torch to cut the aluminum (you will have to switch back and forth). Sure it's not as clean as a laser, but it would probably work with your existing equipment and would be a fraction of the cost, effort, and space of getting a whole new machine. Heck, you wouldn't have to learn how to program a new machine either.
I would look a Hypertherm Powermax45 or Powermax1000, for ~$1600 or ~$2200 respectively. There will be other costs associated with setting each of these machines up on your CNC table, but I do not think you will be able to implement a laser cutter of similar capacity for even close to this amount of money.
EMC linux + CNC mill + CNC Lathe Leav Technical Discussion 8 09-11-2008 23:08
Intelitek CNC Motion - Virtual CNC Machines Kingofl337 Programming 0 19-03-2008 11:29
Laser Rangefinders DavidGitz Control System 14 17-05-2007 17:56
4.3.4.1 - onboard laser? Ethulin Rules/Strategy 29 15-01-2006 13:13
To CNC? Or not to CNC? phrontist General Forum 21 26-03-2004 13:45
