Go to Post One of the most important resources of all: [URL="http://frc-manual.usfirst.org/"]The Manual[/URL] - lorem3k [more]
Unread 09-06-2010, 15:02
byteit101's Avatar
byteit101 byteit101 is offline
WPILib maintainer (WPI)
AKA: Patrick Plenefisch
no team (The Cat Attack (Formerly))
byteit101 is a glorious beacon of lightbyteit101 is a glorious beacon of lightbyteit101 is a glorious beacon of lightbyteit101 is a glorious beacon of lightbyteit101 is a glorious beacon of lightbyteit101 is a glorious beacon of light
ZomB Dashboard 0.6: Beta testers wanted
ZomB Dashboard System 0.6b
ZomB Dashboard System version 0.6 will be released soon, but I need beta testers to help me make sure there are no bugs in it. There are two main parts that need to be tested: dashboard components/controls and a new robot side interface. Since I won’t have access to a cRIO until July 6th (in part due to a vacation), I need you to help me test ZomB.
If you find a bug, reply to this thread, email me, or post on the Testing Feedback FirstForge discussion forum. It would also be nice if you took the time to see why it is doing what it is (and maybe make a patch) so I can fix it easily. I'll try to answer them as soon as I can and get it fixed.
Major parts to test
If it works for you
Default dashboard "Idiot Proofing"
DashboardDataHubPanel
Video sources and CameraView
Design time and run time support of StatusLabel and ValueMeter
TCP support (DashboardDataHub source)
RobotStatusEventMonitor (changes in enabled, auton, etc...)
DataSaver & DataPlayerSource (recording of matches)
The new robot side interface is new and untested (though should work in theory ), and is on FirstForge as New Experimental C++/Java Bindings. Instructions for it are in the ZomB Guide.
Downloads
Download it all: http://firstforge.wpi.edu/sf/frs/do/...e.v0_6_b1?dl=1
Pick and choose: http://firstforge.wpi.edu/sf/frs/do/...stable.v0_6_b1
Complete ZomB Guide (Draft): http://firstforge.wpi.edu/sf/docman/...n.root/doc1047
FirstForge Project: http://firstforge.wpi.edu/sf/projects/zombdashboard
If you are interested in becoming a contributor to ZomB (code, website, permanent tester, etc...), PM or email me.
Bubble Wrap: programmers rewards
Watchdog.Kill();
printf("Watchdog is Dead, Celebrate!");
How to make a self aware robot: while (∞) cout<<(sqrt(-∞)/-0);
Previously FRC 451 (The Cat Attack)
Now part of the class of 2016 at WPI & helping on WPILib
ZomB: a C# Drag and Drop Dashboard byteit101 Programming 39 14-05-2010 21:01
Looking for Beta testers at NJ Regional knittinggears General Forum 4 02-03-2010 18:56
Beta testers needed scitobor 617 Website Design/Showcase 9 30-05-2005 12:48
LINUX Users: Requesting beta testers jdong Programming 35 20-03-2005 13:28
Beta Testers blueWarrior FIRST-related Organizations 4 18-06-2003 19:48
