Re: Crazy Drive Train Ideas
We did this for a community outreach robot. Instead of treaded wheels we used omni wheels. At first, he was designed to balance on it, but we decided to put some casters on him. The large basketball we used got worn down to the fabric.
How did you secure the ball? That's the only issue I have with ball drives.
augers would work, two augers with oposite direction helixes, the spin the opposite direction of each other to go forward or backward, altering the speed that each one drives would achieve holonomicacy. to go sideways, both spin in the same direction, due to the way the screws are set up it will not be vulnerable to pushing from one side while traveling at 90 degrees like mechanum is to some degree, i think ill ask on Q&A next year if that would be legal.
/tangent/
I'm not 100% sure this is a word, but if not, it should be. Or would it just be holonomicy? Either way, it's finding it's way into my vocab. /tangent/ |
/tangent//tangent/
Argh!!!!!! Please say it isn't so! Good words already exist. Take the time to discover and use them. Vocabulary and writing skills are important. Practice using existing words precisely instead of cluttering your vocabulary with ambiguous jargon that only creates the illusion of technical information. FYI - Most good employers care greatly about this.... /tangent//tangent/ Blake Last edited by gblake : 24-06-2010 at 21:25. |
Additionally, it is hard to find a material that can slip against the carpet, yet still have traction, yet won't destroy either the carpet or itself very quickly. The analogy would be if you made a "kiwi" drive (wheels at 45 degree angles to the body) with regular wheels - everything would scrub the ground all the time. It kills your wheels, it kills the carpet, and it kills your efficiency. All of this goes out the window (somewhat) if you are driving in sand, but otherwise I would think long and hard before implementing this. |
http://www.youtube.com/watch?v=L3NGCL-efRM |
![]() If any team wants to mold some enormous Archimedes screws like those, I'd bet you win some kind of technical award. Making weight would be fun though... ![]() Last edited by Ian Curtis : 29-06-2010 at 22:42. |
#11
With 130+lbs on the screws good luck not damaging the carpet from driving or getting pushed around.
#13
From the video, it looks like a rather high lead thread is required to get the speed ratios correct (fore/aft versus sideways). Maybe a multi start thread could be used to keep the lead high but provide more surface area in contact with the ground.
#14
I'm not saying it would be ideally suited for any games other than those containing the fabled FRC water hazards; but it could be fun to make. If you chose the materials carefully, you might be able to create a fun off-road machine that isn't stymied by swampy terrain, and that is also at home on FRC carpets. Blake |
#15
Pushed on a screw drive? Bahahahahahahahahahahaha
| Drive Train Components: the inner working parts of a drive train | naruto137 | Technical Discussion | 3 | 10-12-2008 21:14 |
| drive train | Adama | Technical Discussion | 30 | 14-12-2006 20:56 |
| pic: Jester Drive:Mecanum Wheel Drive Train | Ken Delaney 357 | Technical Discussion | 64 | 29-03-2006 22:16 |
| Drive Train | Thunder360 | Motors | 5 | 21-03-2003 20:41 |
| Drive Train | archiver | 2000 | 1 | 24-06-2002 00:37 |
