Go to Post The problem with random numbers is you never know. - GregT [more]
Unread 06-13-2010, 04:28 PM
Tanner's Avatar
Tanner Tanner is offline
FRC #1261 (Roblions)
Rookie Year: 2007
Tanner is a splendid one to beholdTanner is a splendid one to beholdTanner is a splendid one to beholdTanner is a splendid one to beholdTanner is a splendid one to beholdTanner is a splendid one to behold
Arcade Drive Troubles in Autonomous
Hi all,
I'm almost done with reprogramming this year's robot in C++ instead of LabVIEW. The only thing holding me back from marking it done is the autonomous.
In autonomous I'm telling the robot to go forward like so:
Code:
static const float autonomousForwardPower = -0.5;
//Move forward!
drivetrain->ArcadeDrive(autonomousForwardPower, 0.0);
Same exact drivetrain I use for teleop. I even use the function in teleop. Though it seems no matter what I do the robot turns left at full speed instead of going straight.
I even tried it in teleop and it does the same thing.
So, yeah - I'm confused why this is happening. Thoughts?
-Tanner
Semi-Omni-Arcade Drive byteit101 Programming 20 01-24-2010 08:21 AM
Programming Arcade Drive kyungjin C/C++ 4 04-06-2009 11:28 AM
Non-Arcade Drive causes problems in Autonomous... pinballwizard96 NI LabVIEW 2 02-01-2009 08:45 PM
Arcade/Tank Drive Malfunction piedmont Programming 2 01-19-2009 05:37 PM
Arcade Drive Anfony VEX 4 11-08-2006 07:46 PM
