Go to Post pit visitor: "Why'd you use #35 chain?" team member "less links to CAD...." - Aren_Hill [more]
Unread 13-06-2010, 21:16
isaacdl isaacdl is offline
I have a white hat..it's just dirty
AKA: Isaac Dontje Lindell
FRC #3018 (Nordic Storm)
Rookie Year: 2010
isaacdl is an unknown quantity at this point
range of joystick input?
I'm setting up a throttle control for our bot, using the Z axis (throttle control). The code I'm using to get the value of the Z axis is:
Code:
throttleSpeed = rightStick.getZ() ;
(throttleSpeed is type double.) I need to know what range the value of throttleSpeed could be. Is it -1 to 1, or 0 to 1, or 1 - 255, or something completely different?
Unread 13-06-2010, 21:31
JamJam263 JamJam263 is offline
FRC #0263
JamJam263 is a glorious beacon of lightJamJam263 is a glorious beacon of lightJamJam263 is a glorious beacon of lightJamJam263 is a glorious beacon of lightJamJam263 is a glorious beacon of light
Re: range of joystick input?
Code:
-1 to 1, where -1 is flat, 0 is half way up, 1 is completely up. We've used throttle control the past two years where
Code:
throttleSpeed = (rightStick.getZ()+1)/2 ;
Favorite 2009 quotes:
"Do we really need all of the cRIO or can we cut it in half to save weight?"
Unread 13-06-2010, 21:45
Rookie Year: 2010
Perfect, thank you.
Joystick values out of range Sentient Programming 0 14-02-2009 09:35
Joystick Input Mapping ExarKun666 Programming 14 25-04-2008 08:41
Joystick Input calibration in software LieAfterLie Programming 3 14-02-2007 21:44
issues limiting a joystick input Unholy Programming 7 12-02-2006 19:53
change pwm range preserve input sensitivity Superstitions Programming 6 11-02-2006 20:59
