Re: pic: sheet metal 6WD
The moment of intertia of the cross section is directly related to it's stiffness.
If you google, you'll see for a rectangle, the moment of inertia is 1/12bh^3 (base and height). Base being the side parallel to the axis the beam is being bent around. So, a 5" tall .050" thick plate has an I = 1/12(5in)(.050in)^3 ~ 5x10^-5. The same beam with two 1" flanges is that I plus the I of the two flanges. I = 1/12(.050)(1)^3= .004 So the beam with the two flanges has a total I of .004+.004+5x10^-5 ~.084. .084 / (5x10^-5) ~150:1. Even if I made a mistake in the math somewhere, this demonstrates the difference flanges make in design. I could go on for pages elaborating this, but it'd better to google and look yourself (key terms being beam, cross section, moment of inertia, etc...). You'll also then understand why I-beams are shaped the way they are. |
Similar concepts apply, just inverse. The beam is substantially weaker due to that flange removal. Depending on how the gearbox is attached, the gearbox itself could add a lot of support to the beam where material is removed. |
![]() The loss of a continual flange will not only decrease the second moment of area, but will also "chase" the stresses to the ends of the flange. Last edited by 548swimmer : 22-06-2010 at 02:02. |
If that's the case, what's your basis for saying it'd be okay to remove the bottom flange entirely?
Different design. The flange I said would be okay to remove was the bottom external flange. The top external flange used to mount bumpers will working in tandem with a properly mounted plate should, depending on material thickness, provide more than adequate structural integrity. That's why I said you could most likely remove that flange.
| pic: WCD Sheet Metal Concept Chassis | GarrettF2395 | Extra Discussion | 22 | 20-05-2010 16:33 |
| pic: Sheet Metal Drivetrain | Jacob Paikoff | Extra Discussion | 14 | 30-04-2010 11:21 |
| pic: GUS Team 228's 6WD Sheet Metal Prototype Chassis | artdutra04 | Extra Discussion | 14 | 02-01-2009 02:11 |
| New Sheet Metal Pattern Query | easydub | Inventor | 4 | 13-07-2006 13:55 |
| [OCCRA]: Bending Sheet Metal | troy_573 | OCCRA Q&A | 1 | 19-09-2005 22:27 |
