Go to Post "Greatness isn't achieved by doing the uncommon things but instead by doing the common things uncommonly well." - Wayne C. [more]
Thread Tools Rating: Thread Rating: 3 votes, 5.00 average. Display Modes
Unread 22-11-2010, 19:41
Henry Williams's Avatar
Henry Williams Henry Williams is offline
Vice President Team 461
FRC #0461 (Westside Boiler Invasion)
Team Role: Mechanical
Henry Williams is on a distinguished road
Re: Drive Train Prototype
Just a quick update for everyone interested, since the last post we have fixed the mecanums, we had actually done this a while ago but some of the media was not up to date. We also replaced all the electronics board material with pegboard and we added a shooter so we could use it as a demo/show bot. It is still made of nearly all 80/20 so with the shooter and hopper it probably weighs about the same as a normal FRC bot now (but we haven't weighed it since so thats just an estimate).
Unread 29-06-2010, 11:49
Aren Siekmeier's Avatar
Aren Siekmeier Aren Siekmeier is offline
on walkabout
FRC #2175 (The Fighting Calculators)
Aren Siekmeier has a reputation beyond reputeAren Siekmeier has a reputation beyond reputeAren Siekmeier has a reputation beyond reputeAren Siekmeier has a reputation beyond reputeAren Siekmeier has a reputation beyond reputeAren Siekmeier has a reputation beyond reputeAren Siekmeier has a reputation beyond reputeAren Siekmeier has a reputation beyond reputeAren Siekmeier has a reputation beyond reputeAren Siekmeier has a reputation beyond reputeAren Siekmeier has a reputation beyond repute
Originally Posted by nitbaj View Post
We put the mecanum wheels on the outside because we thought those would be the primary driving wheels, and then the traction wheels would be used in a pushing match or a similar situation. And if a robot with a relatively high center of gravity is moving quickly on mecanum and switching directions, it is much more stable to have the wheels on the outside.
Also, tank turning with the traction wheels will be easier with a shorter wheel base because you will get less tread rub.
Unread 22-11-2010, 20:09
Tom Ore Tom Ore is offline
FRC #0525 (Swartdogs)
Tom Ore has a reputation beyond reputeTom Ore has a reputation beyond reputeTom Ore has a reputation beyond reputeTom Ore has a reputation beyond reputeTom Ore has a reputation beyond reputeTom Ore has a reputation beyond reputeTom Ore has a reputation beyond reputeTom Ore has a reputation beyond reputeTom Ore has a reputation beyond reputeTom Ore has a reputation beyond reputeTom Ore has a reputation beyond repute
We used these Mecanum's this year. They do look a lot sturdier, but the bolts and rather small and can bend easily. Our Breakaway robot had a similar drive, but without the moveable wheels. We used 4 Mecanums on the inside and 4 traction wheels on the outside, raised slightly. This allowed us to cross the bump easily - the traction wheels were geared down and pulled us over the bump. We could cross the bump easily at full robot speed but when the robot came down on the other side of the bump, the bounce would bend the small Mecanum wheel bolts. The electronics guys didn't like us crossing the bump that fast anyway...
Unread 22-11-2010, 21:00
MattC9's Avatar
MattC9 MattC9 is offline
MattC9 has a spectacular aura aboutMattC9 has a spectacular aura aboutMattC9 has a spectacular aura about
Just curious how did you interface the gearboxes to the pods, do you have any CAD files we could look at? Because I was playing around with this idea (like ever one else it seems like) and could not find a good stable way to inter face the transmissions (I was just using the tough box nano in it) also what gear box are you using on it?
Unread 16-05-2012, 08:17
greasemonkey's Avatar
greasemonkey greasemonkey is offline
Truss me I'm a Doctor
AKA: Fred Parker, fredword, fredwardo, phred, frederick
FRC #3467 (windham windups)
Rookie Year: 2011
greasemonkey is an unknown quantity at this point
how many air tanks did you need for that?
Unread 16-07-2010, 18:53
CENTURION's Avatar
CENTURION CENTURION is offline
King of unreasonable designs
AKA: Evan the Shop Princess
FRC #1306 (BadgerBOTS)
CENTURION has a brilliant futureCENTURION has a brilliant futureCENTURION has a brilliant futureCENTURION has a brilliant futureCENTURION has a brilliant futureCENTURION has a brilliant futureCENTURION has a brilliant futureCENTURION has a brilliant futureCENTURION has a brilliant futureCENTURION has a brilliant futureCENTURION has a brilliant future
Is the mesh material you used for the eletronics board that
fiberglass-reinforced plastic that is used for catwalks and the like? Or is it just a plastic mesh?
I've been looking around for a simple plastic mesh to use for electronics boards that isnt the more expensive fiberglass stuff, but haven't had any luck.
Unread 16-07-2010, 19:49
Lil' Lavery Lil' Lavery is offline
TSIMFD
AKA: Sean Lavery
FRC #1712 (DAWGMA)
Lil' Lavery has a reputation beyond reputeLil' Lavery has a reputation beyond reputeLil' Lavery has a reputation beyond reputeLil' Lavery has a reputation beyond reputeLil' Lavery has a reputation beyond reputeLil' Lavery has a reputation beyond reputeLil' Lavery has a reputation beyond reputeLil' Lavery has a reputation beyond reputeLil' Lavery has a reputation beyond reputeLil' Lavery has a reputation beyond reputeLil' Lavery has a reputation beyond repute
Send a message via AIM to Lil' Lavery
The inverse is also true, it will also be easier for you to be turned.
A longer wheel base grants more resistance to rotation, both caused by your robot, as well as caused by other robots. This is precisely why 148 and 217 opted to put their traction wheels on the outside, as they only planned to use them in pushing matches and why they were attempting to hold their position.
It all comes down to precisely what you want to accomplish with the drive system. There are reasons and rationales behind all sorts of different wheel configurations.
Unread 18-07-2010, 02:14
on walkabout
But the robots motors will have to be back driven for this to happen... The tread rub in tank turning is sideways, but there is still traction inline with the wheels, and this doesn't go away when transverse tread rub is reduced. Rotation of the robot will still require that the wheels turn, and therefore the motors are back driven, or the treads slip. If you are powering the motors, like during a pushing match, you should be fine if the traction is enough.
Unread 18-07-2010, 12:48
TSIMFD
AKA: Sean Lavery
FRC #1712 (DAWGMA)
I bolded the key point in your statement, "or the treads slip." The treads can slip sideways when an external force is applied. Draw up some free body diagrams and think about the problem some more, and it become quite clear why a long wheel base can resist more torque before having the wheels slip.
Unread 18-07-2010, 14:39
AdamHeard's Avatar
Lead Mentor
FRC #0973 (Greybots)
Physics are right on this one, that's the beauty of it.
Unread 20-07-2010, 16:28
nitbaj's Avatar
nitbaj nitbaj is offline
AKA: Nitesh Bajaj
nitbaj will become famous soon enough
For the electronics we just used some plastic eggcrate (I think that's what it's called). We just got it at a local hardware store, and it's similar to this:
http://www.goodmart.com/products/1133880.htm
It isn't the sturdiest material, though and after a lot of driving and running into things, the plastic snapped in a few mounting places, so we're planning on swapping it out for something else soon. It is nice for prototyping because it is quick and easy to put on, but I wouldn't necessarily recommend it for a robot you want to be able to take some impact.
Unread 23-07-2010, 04:21
CENTURION's Avatar
Ah, cool...
You might want to try out some of this stuff:
http://www.corrosionfluid.com/fiberg....aspx#benefits
Or something similar, apparently the FRP (fiberglass-reinforced-plastic) is pretty strong (people can stand on it) though I can't seem to find any with a mesh smaller than 1.5"x1.5", and I'm not too sure about the pricing.
Drive Train ryan25 General Forum 28 23-12-2009 21:49
pic: 1885's Drive Train Prototype JesseK Extra Discussion 5 01-02-2009 02:11
Drive Train Components: the inner working parts of a drive train naruto137 Technical Discussion 3 10-12-2008 21:14
pic: Jester Drive:Mecanum Wheel Drive Train Ken Delaney 357 Technical Discussion 64 29-03-2006 22:16
Drive Train Thunder360 Motors 5 21-03-2003 20:41
