Re: pic: 2011 Drive Prototype
For the original poster: How do you intend to manufacture your gears? I'm guessing our 2007 robot was the inspiration for this design based on some of the aspects you've chosen to incorporate. If you've read much about that robot you'll have seen that everyone involved with the robot agrees that it's simply not worth the time and cost to make aluminum gears, for the ~2-2.5 lb weight savings. Additionally we have moved away from delrin in the past two years. It flexes too much and isn't as durable as aluminum. If you have access to a waterjet it becomes very easy to make pocketed .250" aluminum gearbox plates which will be comparable in weight to .250 delrin but much more rigid. If you have access to a CNC mill, which I assume you do based on your design, it's a little more work, but still fairly simple. If you intend to make this as a prototype, you should probably understand the basics of how the design actually works. If you're just copying it and drawing it in CAD with no understanding of why things are done the way they are, then what value is that bringing to your team? Last edited by Cory : 28-06-2010 at 17:32. |
Delrin is an easier material for us to mill because we do not have access to a vmc yet, just a prototrak machine. I do understand how the design works, just i did not want to give him wrong information so that i do not confuse him. PM me so that i can explain. Last edited by MWB : 28-06-2010 at 17:44. |
Why the secrecy with the tensioning method? I have to assume that most all of your design inspiration exists because of a lack of secrecy and the willingness of others to share ideas and to develop understanding.
or a design. So we might not even end up doing the design. |
We make 100% of all our CNC milled parts on a ProtoTrak. We have absolutely no problems cutting any kind of aluminum. What sort of problems are you having? Also, about the tensioning system...it seems extremely similar to 254s, why are you keeping it secret? -Brando |
Well its the way the cams are turned, not the actual system. |
They slide inside of of a square cutout, while a cam (involute of a circle) with lots of tiny ridges sort of ratchets into place. the ridges fit onto the radius of the bearing block. PM Cory if you want to get the total lowdown.
How are you putting the frame together? Bolts and brackets? Welding? The concept is good (though you should have some additional triangulation as some have mentioned). You just need a little more detailing for it to be 100%.
Yes all the materials are set. The reason that it is so light is because the upper-structure is made of 1/16in aluminum They are made of 1/4in Delrin and 7075 Aluminum Last edited by MWB : 28-06-2010 at 16:25. |
| 2992 with 5 motor 2011 Prototype Drive System | 45Auto | General Forum | 4 | 22-04-2010 23:01 |
| pic: 2826 Halonomic Drive Prototype | Tyler Olds | Extra Discussion | 15 | 10-12-2009 22:38 |
| pic: 1010 Drive system prototype | joeweber | Extra Discussion | 10 | 24-08-2009 15:28 |
| pic: 1885's Drive Train Prototype | JesseK | Extra Discussion | 5 | 01-02-2009 02:11 |
| pic: 213 - Drive prototype teaser | Tyler M. | Robot Showcase | 10 | 07-01-2007 20:56 |
