Go to Post Capability and willingness are two very different things. Anybody can dance, though you could spend your lifetime unsuccessfully trying to convince them of that. - Mr. Pockets [more]
Unread 30-06-2010, 18:50
Team#2057-Vegas's Avatar
Team#2057-Vegas Team#2057-Vegas is offline
Team2057LasVegas
AKA: Justin Major
FRC #2057 (AV CyberBulls)
Team Role: Leadership
Team#2057-Vegas can only hope to improve
Another Labview Setup Check
I tried fixing it based off of others ideas in another forum, but it still isn't working. Below is my entire code for this robot. If anyone can look at it, it would be appreciated. The robot hasn't changed much.
Please do enjoy my humor.
Justin Major
2057 Team Leader
"We will kick you off our pasture" -- 2057 Motto
Unread 30-06-2010, 19:13
Mark McLeod's Avatar
Mark McLeod Mark McLeod is online now
Just Itinerant
AKA: Hey dad...Father...MARK
FRC #0358 (Robotic Eagles)
Re: Another Labview Setup Check
In teleop.vi you should not use "Close" for any of the devices.
Nothing will be Open any longer after the first time teleop is called.
That just turns everything off in the first 1/50 second.
The Closes you have in Finish.vi are all you want.
Begin.vi looks okay.
Finish.vi looks okay.
Autonomous Independent.vi looks like the default.
Unread 01-07-2010, 03:00
Team2057LasVegas
AKA: Justin Major
mark, how should i end the case structure each time then? it would have unfinished wires and things just sitting inside
Justin Major
2057 Team Leader
Unread 01-07-2010, 08:01
Just Itinerant
The last vi icons just shouldn't have wired outputs if they have nowhere to go.
Unread 01-07-2010, 12:55
Team2057LasVegas
AKA: Justin Major
ah that makes more sense now! thank you mark once again. I'll go try it
Justin Major
2057 Team Leader
Unread 01-07-2010, 14:26
Team2057LasVegas
AKA: Justin Major
GOOD NEWS! The robot works. We're having a little trouble with the compressor, but I think I can work that one out. Thanks again Mark!
Justin Major
2057 Team Leader
Wireless setup Al3+ Programming 7 30-01-2010 14:30
[FTC]: Problem with two controller setup in Labview wilsonmw04 FIRST Tech Challenge 2 11-11-2008 19:58
Another electical setup idea from my team fo 08... cdennisxlx2 Electrical 13 11-10-2007 13:47
PALMBOT --palm robot (another one...) CHECK IT OUT! archiver 2001 1 24-06-2002 02:57
121, another competition, another victory. Greg Perkins Off-Season Events 27 06-06-2002 23:13
