Go to Post it's shadows and fog and stormy skies and a reminder that things are rarely black and white but instead, the places in between. - MissInformation [more]
Unread 01-07-2010, 14:04
Lisa Perez's Avatar
Lisa Perez Lisa Perez is offline
FRC #0573 (Mech Warriors)
Lisa Perez has a reputation beyond reputeLisa Perez has a reputation beyond reputeLisa Perez has a reputation beyond reputeLisa Perez has a reputation beyond reputeLisa Perez has a reputation beyond reputeLisa Perez has a reputation beyond reputeLisa Perez has a reputation beyond reputeLisa Perez has a reputation beyond reputeLisa Perez has a reputation beyond reputeLisa Perez has a reputation beyond reputeLisa Perez has a reputation beyond repute
User can send commands but cannot read sensor data over Bluetooth
I have created a LabVIEW VI that allows me to control an iRobot Create robot through a Bluetooth connection. Writing commands to the Create works just fine - I am able to drive, stop, request sensor data, etc. However, actually reading sensor data from the Create has proven to be more of an issue.
I have the code set up such that it requests sensor data from the Create, waits for 50ms, determines how many bytes are at the port, and then reads the bytes from that port. I tested this over a wired connection, and it worked just fine, showing 1 or 2 bytes at port depending on what sensor data I requested at that point in time. Over the Bluetooth connection, however, it showed that there were 0 bytes at the port, regardless of what sensor data I requested.
It seems that the Bluetooth connection may be the issue, but, as I have limited experience with Bluetooth, I do not really know how to configure it to allow me to get that sensor data (if indeed the connection is the issue). Any tips?
Thanks!
Event Coordinator - Center Line District Event
Volunteer Coordinator - Michigan State Championship
Lead Mentor - Team 573, Mech Warriors
Former Mentor - Team 830, Rat Pack and Team 3182, Athena's Warriors
Proud Alumna - Team 573, Mech Warriors and Team 1, Juggernauts
Sending user data, parsing user data. demosthenes2k8 NI LabVIEW 3 30-01-2009 13:51
Help! Can't send files to NXT Brick via bluetooth Raptorace22 National Instruments LabVIEW and Data Acquisition 0 24-11-2008 16:39
Using the IR remote to send radio commands to the robot Mikhail_Pham Control System 2 14-01-2008 00:14
Can the pic controller send the data to pc? sunnyrx7turbo Control System 2 05-08-2005 13:14
