paper: Kitbot Bending Analysis
Thread created automatically to discuss a document in CD-Media.
Kitbot Bending Analysis by kramarczyk |
Re: paper: Kitbot Bending Analysis
Thanks for posting this up. There are a lot of interesting tid-bits to gather from this.
A couple of take-aways I got were: A reminder of the lack of stiffness in an open rail section (see Ford commerical for "Fully Boxed Frame"). Another great point is the importance of spaceframe and triangulation vs. cantilevered structures. Overall, I still think the Kit was a pretty reasonable unit that accomplished the goal of a fairly simple mobility solution for many teams. While the classic layout (flat chassis) has always suffered from torsional stiffness issues (this is a benefit for the Mecanum guys), this one seems to be especially strained due to the larger moments from the stand-offs. While some may be upset with this, I think a great number of teams learned some very important lessons this build season. This study is a clear example of that. |
You guys did a good job of determining the root cause and analytically solving the problem.
I don't think your FEA is set up totally correct, but it is close enough to show what you are trying to. Good job to you and your team. -Brando |
I agree that the FEA rough, but adequate. What would you change about it?
We are continuing to struggle with the same chain issues. We thought we had traumatized the frame by our elevating technique; unfortunately it appears that simply driving the robot creates stress. This will be great strategic knowledge to implement at IRI.
I'm curious - what types of wheels did you use? We have slicks in front and stickies in back; I'm convinced the extra grip in the stickies can exaggerate the frame bending. Do you feel the same way? |
Also, the load of 300 lbf in an arbitrary direction is a critical assumption. How was that arrived at? I can't help but think there needs to be some consideration of the other forces transmitted through the wheel and the frame in a collision—even in a static case, isn't the loading significantly more complicated in real life? Even neglecting other components of the loading, and focusing on this principal one, what was the reasoning behind this particular magnitude? And because the material isn't actually homogeneous, you've got to be careful with your conclusions about the areas of peak stress which lie in strain-hardened areas (like corners that have been bent on a break). You're probably going to have stronger material in that area—counteracting some of the stress—but with more crack initiation sites that can fail (maybe in low-cycle fatigue). Since the safety factor calculation assumes homogeneous material, there's significant uncertainty here as to when failure (either by yielding or fracture) will actually occur. Now of course, if you just picked this as a worst-case scenario, that seems quite reasonable as a rough estimate. But then it implies that you're not going to put too much stock in the safety factor calculations, because they're necessarily imprecise. It gives you a good order of magnitude study, tests relative performance of several options and highlights points of failure, but won't allow you to say with confidence exactly what the failure loads are. So basically, it's a useful exercise, as long as the students are clear on its limitations. The key is to treat this as an estimate, rather than "the solution" (as if it was a deterministic math problem). I think that's basically what you guys noted in your conclusions—good work! |
Interesting analysis of this problem
http://www.chiefdelphi.com/forums/sh...ad.php?t=84330 The kit frame is a decent design for all but this years' game. |
Now if I was building a sattelite or a racecar, I would want better detail, but this is an excellent swag for this sort of analysis. |
#10
Great bunch of questions.
A single CIM outputs 2.42 N-m of torque at stall which converts to 21.4 lbf-in. The kit toughbox has two 14:50 stages in it for at torque amplification of 21.4*50/14*50/14 = 273 lbf-in The output sprocket is a 15 tooth #35 sprocket. 15 teeth * .375" pitch = 5.625" circumference. 5.625" / 3.14 = 1.8" diameter. 1.8"/2 = .9" radius. 273 lbf-in / .9" = 303 lbf of chain tension. I rounded to 300 lbf because it simple. With 2 CIMs per side there would be capacity for 600 lbf of chain tension. With all of that being said, these load can only be achieved if they are countered by the traction of the wheel. During normal operation of the robot (driving on a flat surface) the normal force for each wheel would be around 37.5 lbf (assuming a central CG location). With the kit 8" traction wheels (published mu of 1.0) they are capable of resisting a 150 lbf-in torque at the wheel. The kit provided 22 tooth #35 sprockets for the wheels. 15 teeth * .375" pitch = 8.25" circumference 8.25" / 3.14 = 2.63" diameter 2.63" / 2 = 1.31" radius 150 lbf-in / 1.31" = 114 lbf of chain tension resistance. This is clearly less than the 300 lbf number used in the analysis. In order to reach those higher chain tensions a transient condition is required that increases the normal load on the wheel. A trainsient like this can easily be achieved during contact with the bumps on the field, ramps in front of the goals or during contact with other field elements or robots. This is where the analysis gets a little funny. As you mention, this is a complicated interaction and I would feel foolish trying to defend a specific load case. I took a simpler route and viewed it as a safety factor. I felt that the transient had the capacity of increasing the normal force by 2.5-3x momentarily, so that made the 300 lbf load achieveable. There is debate as to if this was a reasonable assumption; I would love to hear alternate approaches. Quote:
| Bending Metal | Jeremiah Johnson | FIRST Tech Challenge | 2 | 01-05-2006 01:15 |
| White Paper Discuss: Physics Analysis of a Ball Launcher | coastertux | Extra Discussion | 0 | 01-02-2006 17:58 |
| White Paper Discuss: Analysis of Ball Drag from Fundamental Physics | coastertux | Extra Discussion | 0 | 01-02-2006 16:49 |
| bending parts | foobert | FIRST Tech Challenge | 4 | 15-01-2006 13:17 |
| White Paper Discuss: Team 670 - Universal Drive Systems: Design and Analysis | ChrisCook | Extra Discussion | 13 | 01-07-2005 23:41 |
