Go to Post [I] [/I]I think this may be some kind of record. We got through 9 entire posts before someone mangled the spelling of mecanum. [I] [/I] - Ether [more]
Unread 13-10-2001, 23:02
patrickrd's Avatar
patrickrd patrickrd is offline
AKA: Patrick Dingle
Rookie Year: 1999
patrickrd is a splendid one to beholdpatrickrd is a splendid one to beholdpatrickrd is a splendid one to beholdpatrickrd is a splendid one to beholdpatrickrd is a splendid one to beholdpatrickrd is a splendid one to beholdpatrickrd is a splendid one to behold
Send a message via AIM to patrickrd
Question Robot Controller & Operator Interface troubles
Last week our team did a demonstration outdoors on a rather warm (~75 degrees) and sunny day. Our robot powered up just fine and started off working like normal, but after about a minute the robot would stop working. It would basically randomly start and stop working throughout the day. Upon closer inspection, the "No Data/Signal" light was blinking red on and off. After about an hour or two of checking every wire on the robot (we even had the same trouble when using tether!) and kicking the robot violently, we were convinced our robot controller or operator interface was screwed up in some way. Then we postulated that the robot was working whenever the sun went behind the clouds (or clouds in front of the sun, depending on your views and personal beliefs of how the solar system works), and stopped when it was sunny. This was hard to rigorously check, but it did seem to have a greater chance of working after being in the shade for a bit.
Then, we did another demo that night -- indoors -- and everything worked fine.
Has anyone seen this before??? It had me mighty confused.
Patrick
How much planning goes into your robot? Jnadke General Forum 41 29-01-2006 21:29
serious problem found - robot controller resets when jarred! KenWittlief Electrical 23 19-03-2003 13:30
Controlling a FIRST robot with a Lego RCX Controller? archiver 2001 5 24-06-2002 04:19
WASH Palm scouting at the Championship Mike Soukup Scouting 2 19-04-2002 15:14
about how Drive Train push the robot... shouldn't the force accelerate the robot? Ken Leung Technical Discussion 12 26-11-2001 09:39
