Go to Post If this information is not 100% correct, you should follow the default advice I have for when anything goes wrong: Blame the Programmers - IKE [more]
Go Back   Chief Delphi > Technical > IT / Communications > 3D Animation and Competition
Unread 23-07-2010, 06:11
yara92's Avatar
yara92 yara92 is offline
M.Fawdah Mechanical engineering
AKA: Mohamed
FRC #1946 (Mechka Monster)
Team Role: RoboCoach
yara92 will become famous soon enoughyara92 will become famous soon enough
How to learn and downlowd for team FRC Autodesk Inventor 3ds Max
I am intresting How to learn and downlowd for team FRC Autodesk Inventor 3ds Max,
for the FRC 2011
TEAM 1946-Tamra
Unread 23-07-2010, 08:48
ttldomination's Avatar
ttldomination ttldomination is offline
Sunny
Rookie Year: 2007
ttldomination has a reputation beyond reputettldomination has a reputation beyond reputettldomination has a reputation beyond reputettldomination has a reputation beyond reputettldomination has a reputation beyond reputettldomination has a reputation beyond reputettldomination has a reputation beyond reputettldomination has a reputation beyond reputettldomination has a reputation beyond reputettldomination has a reputation beyond reputettldomination has a reputation beyond repute
Re: How to learn and downlowd for team FRC Autodesk Inventor 3ds Max
You should be able to register here, and then download any of the Autodesk Software, including 3ds Max.
1648: 2013-2014
5283: 2015
Unread 25-07-2010, 07:30
yara92's Avatar
AKA: Mohamed
thanks i have downlhoded it however i only have it for 30 days and really not sure how to activate it for my FRC team....
i would be grateful for good tutorial links... for biggners
TEAM 1946-Tamra
Unread 25-07-2010, 10:10
Clem1640's Avatar
Clem1640 Clem1640 is offline
Head Mentor
AKA: Clem McKown
FRC #1640 (Sab-BOT-age)
Team Role: Leadership
Clem1640 has a reputation beyond reputeClem1640 has a reputation beyond reputeClem1640 has a reputation beyond reputeClem1640 has a reputation beyond reputeClem1640 has a reputation beyond reputeClem1640 has a reputation beyond reputeClem1640 has a reputation beyond reputeClem1640 has a reputation beyond reputeClem1640 has a reputation beyond reputeClem1640 has a reputation beyond reputeClem1640 has a reputation beyond repute
All teams registered for the 2010 season should have received a link via email for the download of 1-year licenses. These links are unique for each team. We received ours on 28-Oct-2009. Speak with your team's TIMS contact.
Clem McKown
Head Mentor - FRC 1640 & FTC 7314
Chairman - Downingtown Area Robotics
Unread 25-07-2010, 12:03
Sunny
Rookie Year: 2007
After you download the product, I do believe there is an option for tutorials as well. I learned Inventor via those tutorials and while they're not the best, they lay down a solid foundation.
1648: 2013-2014
5283: 2015
Unread 29-07-2010, 19:00
M.Wong's Avatar
M.Wong M.Wong is offline
FRC #0503 (Frog Force)
M.Wong is a jewel in the roughM.Wong is a jewel in the roughM.Wong is a jewel in the rough
He is asking for a tutorial on how to validate the license for Inventor. What year of Inventor are you running?
Unread 29-07-2010, 22:16
Tony.Wu Tony.Wu is offline
Carnassial
AKA: Dave The Mechanic
FRC #3132 (The Thunder Down Under)
Team Role: Animator
Rookie Year: 2010
Tony.Wu is an unknown quantity at this point
Send a message via MSN to Tony.Wu
there should be a serial which you can use on the same page as the download link
Unread 30-07-2010, 07:36
yara92's Avatar
AKA: Mohamed
thank you
but I found some nice vidio for learning 3dMax
I use 3ds Max 2011. I think there is some renew during summer
I recived this answer "Thank you for your feedback! Attached is a copy of your submission. If your submission requires a response, we will respond as soon as possible. We appreciate your input!"
TEAM 1946-Tamra
What is the difference Between Autodesk Inventor and 3ds Max? sfcaddesigner CAD 3 13-02-2008 14:12
how to import the inventor files in to 3Ds Max beschi 3D Animation and Competition 1 07-09-2007 12:26
How to convert from Inventor to 3ds Max Thyferra2680 3D Animation and Competition 2 16-01-2007 12:10
3Ds Max 7 and Inventor Professional compatibility cbale2000 3D Animation and Competition 2 13-01-2007 09:14
Autodesk Inventor -> 3ds Max (File Format) Adrian Wong Inventor 1 22-01-2002 23:06
