Go to Post While grandmothers are pretty cool, I would be hesitant in letting them determine what is and is not a robot. - Kellen Hill [more]
Go Back   Chief Delphi > Technical > Electrical > CAN
Unread 23-07-2010, 21:12
kamocat's Avatar
kamocat kamocat is offline
Test Engineer
AKA: Marshal Horn
FRC #3213 (Thunder Tech)
kamocat is just really nicekamocat is just really nicekamocat is just really nicekamocat is just really nicekamocat is just really nice
Send a message via AIM to kamocat Send a message via MSN to kamocat
passive reading speed and position
I'm trying to record speed and position of the jaguars, for motion tracking purposes. (I want the robot to record its location)
I'd like this to happen regardless of the control mode or enabled state of the motor. It's just a status command, so it should work, shouldn't it?
It doesn't appear to.
I've opened each Jaguar in voltage mode, and set the number of encoder lines, and done a position reference and a speed reference. screenshot (I overrode the logic so that the speed and position referencing will happen regardless of the mode.)
This is an important issue in the usability of CAN.
-- Marshal Horn
Strategy for Passive Robots (with no attack system) MikePres General Forum 7 08-02-2009 17:39
Drive Control, Wheel Speed Calibration, and Rapid Speed Changes 7-11number1 Programming 3 23-01-2008 20:36
Reading and writing to RX/TX on vex whsrobotics Programming 1 24-02-2006 22:03
Reading binary data from a file and writing it in VB complete Programming 1 02-01-2006 21:21
Problem with reading and writing EEPROM DKolberg Programming 4 16-03-2004 19:29
