How to make backwards forward?
Hello, I am new to programming and on my robot we have 4 wheels. The only problem is that the front wheels are backwards so when we try and go forward with all 4 wheels, the front wheels go backwards while the back wheels go forward. How would we make the robot's front wheels go backwards while the back wheels go forward and vice versa. Here is what our code looks like. Sorry about the format.
#include "WPILib.h" /** * This is a demo program showing the use of the RobotBase class. * The SimpleRobot class is the base of a robot application that will automatically call your * Autonomous and OperatorControl methods at the right time as controlled by the switches on * the driver station or the field controls. */ class RobotDemo : public SimpleRobot { RobotDrive myRobot; // robot drive system Joystick stick; // only joystick public : RobotDemo( void): myRobot(1, 2, 3, 4), // these must be initialized in the same order stick(1) // as they are declared above. { GetWatchdog().SetExpiration(0.1); } /** * Drive left & right motors for 2 seconds then stop */ void Autonomous(void) { GetWatchdog().SetEnabled(false); myRobot.Drive(0.5, 0.0); // drive forwards half speed Wait(2.0); // for 2 seconds myRobot.Drive(0.0, 0.0); // stop robot } /** * Runs the motors with arcade steering. */ void OperatorControl(void) { GetWatchdog().SetEnabled(true); while (IsOperatorControl()) { GetWatchdog().Feed(); myRobot.ArcadeDrive(stick); // drive with arcade style (use right stick) Wait(0.005); // wait for a motor update time } } }; START_ROBOT_CLASS(RobotDemo); |
Re: How to make backwards forward?
You can either reverse the wiring or invert the motor direction in software. This thread has the detailed answers you need.
| How to make a .lib? | duane | Programming | 1 | 16-02-2008 02:25 |
| How Do You Make a PB & J? | JaneYoung | Chit-Chat | 39 | 07-10-2006 19:59 |
| How to make a MAVERICK shirt. | Corey Balint | General Forum | 6 | 20-04-2006 00:44 |
| Help how to make a forum | was217now1509 | Website Design/Showcase | 12 | 25-02-2005 22:37 |
| How to make a max speed | Team 668 | Programming | 3 | 02-02-2005 17:54 |
