Re: Drive train questions
Here's the mandatory "it depends on the game" disclosure: if it's a wide-open field, like 2008, where a robot can get up to speed and maintain that speed for a good portion of the match then a very fast robot would be more useful. If it's a segmented field, much like 2010, where there is not as much room to accelerate and maintain a high speed, a robot might be more effective (i.e. have a higher average speed) if it could reach a lower top speed faster. |
In essence (be sure to keep units in check):
Robot Speed (feet/sec) = Wheel Circumference (feet/rotation) * Wheel Rotation Speed in (rotation/second) = [Pi * Diameter] * [Motor Rotation Speed / Gear Ratio] Assuming Diameter = 8" (0.67 feet) and Motor RPM for a CIM is ~= 5400RPM (90 rot / sec) 15fps = Pi * .67 ft * 90 rot/sec / GearRatio or Gear Ratio = Pi * .67 * 90 / 15 = 12.65:1 for a 15ft/sec bot with 8" wheels. Feel free to put in the numbers for 4ft/sec. |
The limiting factor will be the traction of your wheels. Once your wheels spin in place when your robot pushes against an immovable object, you're done. Gearing lower won't make you push harder, so you might as well gear your robot to right at that point in order to preserve whatever speed you have. However, if that takes more than about 40 amps of current per motor to happen, you will trip your robot's thermal circuit breakers. You can mathematically calculate that gear ratio based on your robot's wheel size, the motors you're allowed, the maximum current you want to draw, and whether or not you've reached your maximum pushing force ("traction limited"). The number's somewhere in the ballpark of 4.5fps for roughtop tread (CoF 1.3), but I'd encourage you to figure that out for yourself. However, gaining that ability leaves you with a very low top speed. Not many FRC events could be easily won with a robot that only goes 4.5 feet per second! If you want to go faster, either you lose the ability to push against anything forever, or the traction of your wheels is going down reducing your pushing force. That, or you use a shifting transmission and go for both. Now, the first question: The vast majority of drivetrains require skidding wheels (the exceptions are generally too complex for someone like me to have anything to do with), so your drive will need to be limited by traction at some amperage. This doesn't necessarily need to be 40 amps, since the breakers do not immediately trip and you rarely need to turn for more than a few seconds, but you're obviously constrained by the stall current of the motors, etc. I doubt you'll be gearing your robots close enough to the stall current to matter though because of the concern of acceleration. You also want to weigh how fast you need to accelerate and how quickly you need to get to something x feet away. At lower speeds (under 8-9 fps or so) you'll probably get to something 5 feet away relatively quickly. Acceleration becomes more of an issue when you get to speeds in excess of 11-12 fps, roughly. How much of an issue depends on the game, how far and fast you need to go in that game, etc. so you'll have to decide for yourself on that one. Luckily someone from team 1640 posted a nice whitepaper on the topic. In short, there's a lot to consider and no stock answer; that's why more teams don't build identical drivetrains every year. One more thing I want to add, is that how fast you can achieve a game objective is often less affected by the gearing of your drivetrain than you might think. |
| Aluminum sprockets for drive train - several questions | M. Mellott | Technical Discussion | 16 | 16-12-2008 15:53 |
| Drive Train Components: the inner working parts of a drive train | naruto137 | Technical Discussion | 3 | 10-12-2008 21:14 |
| Drive Train Questions | Ryank | Technical Discussion | 3 | 16-01-2008 11:07 |
| Questions on Mecanum Drive Train | charmed862 | General Forum | 3 | 09-01-2008 22:23 |
| pic: Jester Drive:Mecanum Wheel Drive Train | Ken Delaney 357 | Technical Discussion | 64 | 29-03-2006 22:16 |
