Go to Post Teach 'em young, and they will go far. - Vashts6583 [more]
Unread 08-11-2010, 05:54 AM
sithum sithum is offline
Junior Member
sithum is an unknown quantity at this point
javascript data type ?
Hi ,
I am sending a function an array of values
which contain '09' , '15','20' ,...etc
everything is working fine except when I have to do something with '09' it seems to truncate off the zero at the begining and pass to the function a 9 instead of a 09
What I want to know is how do I make the function interpert the value as 09 it seems to be converting the parameter to a number instead of the string value '09'
array[0] = '09';
array[1] = '15';
..etc
Thanks for any help
Unread 08-11-2010, 05:38 PM
RyanCahoon's Avatar
RyanCahoon RyanCahoon is offline
Disassembling my prior presumptions
FRC #0766 (M-A Bears)
Rookie Year: 2007
RyanCahoon has a reputation beyond reputeRyanCahoon has a reputation beyond reputeRyanCahoon has a reputation beyond reputeRyanCahoon has a reputation beyond reputeRyanCahoon has a reputation beyond reputeRyanCahoon has a reputation beyond reputeRyanCahoon has a reputation beyond reputeRyanCahoon has a reputation beyond reputeRyanCahoon has a reputation beyond reputeRyanCahoon has a reputation beyond reputeRyanCahoon has a reputation beyond repute
Re: javascript data type ?
sithum,
can you give more detail about what you're trying to do with the values?
I tried your example:
Code:
<html>
<body>
<script type="text/javascript">
var arr = new Array();
arr[0] = '09';
arr[1] = '15';
arr[2] = '20';
for(var i in arr)
  document.write(arr[i]+'<br/>');
</script>
</body>
</html>
which seems to render fine as
Code:
09
15
20
--Ryan
FRC 2046, 2007-2008, Student member
FRC 1708, 2009-2012, College mentor; 2013-2014, Mentor
FRC 766, 2015-, Mentor
p1_sw_aux data type personfromhell Programming 8 02-02-2008 06:40 PM
printing FLOAT data type on the terminal window razer Programming 14 02-05-2007 08:55 AM
javascript ate my cereal! steveg IT / Communications 2 03-29-2004 01:10 AM
Field Location of Type-0 and Type-1 IR Signals Travis Hoffman General Forum 3 02-27-2004 07:58 AM
