Go to Post I think I have a warning label saved somewhere on my computer that says "Warning: All photos taken with this camera may be photoshopped" but I keep forgetting to put it on my camera. - MissInformation [more]
Go Back   Chief Delphi > Technical > Electrical > CAN
Unread 21-08-2010, 20:25
randalcr's Avatar
randalcr randalcr is offline
Programming Mentor
AKA: Chance Randall
FRC #0476 (Wildcats)
randalcr is an unknown quantity at this point
Question Crio and CAN
Ok, so our team has been playing around with CAN be it seems we're not doing something right. Is there a guide anywhere that shows you how to set up CAN step-by-step or something along the lines of that? we can write the code to use CAN easy enough, its when we start trying to talk to the jags through the crio that we start getting problems.
We a using the serial port on the Crio, we are fairly sure we can rule out our cables since we can see all of the jags on the network when we use the BDC comm, and we are only using 3 to 4 jags total.
any input is appreciated and helpful, Thanks!
-Time is the best teacher...unfortunately it kills all of its students. --Robin Williams
Can not connect to cRIO z.s.tar.gz Programming 2 13-02-2010 19:06
Does the cRio cut motors at 5.5Vdc on CAN? Mike9966 Electrical 5 10-02-2010 18:05
Can ping CRIO and bridge, but DS shows no comm and no code Green2 FRC Control System 3 22-01-2010 23:55
cRIO Does Not Communicate, Yet Can Be Pinged and Re-Imaged 1951-44U FRC Control System 7 15-12-2009 21:25
pic: cRIO CAN Jag Andrew Schuetze Extra Discussion 63 25-07-2009 01:48
