2010 Image Demo
Hey I have a question about the 2010 Image Demo. Do you need to have a gyro in order for it to work? Also, the camera is hooked up but doesn't show on the driver station. Is this normal?
Re: 2010 Image Demo
I believe the Gyro is only necessary in Autonomous. If you don't have it hooked up, then your direction will always be 0.
The camera image should show up on the Dashboard if it is hooked up and correctly configured. There are instructions for camera configuration on page 58 of Chapter 2 of the Control System Manuals at http://usfirst.org/frccontrolsystem. |
Re: 2010 Image Demo
I have a problem, when I type in the cameras ip, it asks me to log in. I type root for the username and pass for the password but it doesn't accept it. When I enter the username and password it looks like it refreshes. Any ideas?
Re: 2010 Image Demo
Internet Explorer worked correctly. |
Re: 2010 Image Demo
I followed all the instructions and this time used internet explorer and everything looked like it worked but we are still not seeing a camera image in the driver station. We can see the camera image when attempting to modify though.
Re: 2010 Image Demo
Is the ring of light on the camera green when the robot is running?
also fyi the camera takes much longer to boot than the rest of the robot, so the images starting will be slightly delayed |
Re: 2010 Image Demo
Are you saying that the Dashboard shows the camera image when run as a VI, but not when run as an .exe?
Re: 2010 Image Demo
The camera light is green but on the dashboard, the camera image is white.
Re: 2010 Image Demo
Could you take a screenshot?
If it's that dimpled texture, then that means it's not getting an image. If it's actually solid white, then that means the image it's receiving is all white, which is a strange image indeed. |
#10
Re: 2010 Image Demo
Here is a screenshot.
Last edited by Rangel(kf7fdb) : 07-09-2010 at 10:36. Reason: Didn't upload attachment properly |
#11
Re: 2010 Image Demo
How come your Dashboard is broken?
#12
Re: 2010 Image Demo
If you look in the top right corner just above the actual dashboard, you will see an arrow. When the arrow is broken like it is in your picture, it means something isn't wired right on the block diagram. That's probably why you aren't getting a picture.
| Decoupling the image acquisition from the Image Processing | Tom Line | Programming | 8 | 09-03-2010 17:52 |
| 2010 FRC camera vision tracking delay, image processing lag | pspeer | C/C++ | 18 | 18-02-2010 07:24 |
| Running a .out file from 2009 with a 2010 image | GabeRC1717 | C/C++ | 4 | 14-01-2010 16:19 |
