Go to Post When fun is outlawed, only outlaws will have fun. - Gadget470 [more]
Unread 09-09-2010, 01:02 PM
masoug's Avatar
masoug masoug is offline
Food Consumer
FRC #0114
masoug is an unknown quantity at this point
Question How To Use The WindRiver Dev Shell
Hi,
I found out about the WindRiver development shell (wrenv), I I think it has the capability to build robot code without using the WindRiver Workbench.
Has anyone done this before? We have some programmers who can't get WindRiver Workbench to work, so this seems like a good idea...
Thanks!
-Masoug
JabbaScript
Unread 11-22-2010, 11:26 PM
taichichuan's Avatar
taichichuan taichichuan is offline
Software Mentor
AKA: Mike Anderson
FRC #0116 (Epsilon Delta)
Rookie Year: 2010
taichichuan has much to be proud oftaichichuan has much to be proud oftaichichuan has much to be proud oftaichichuan has much to be proud oftaichichuan has much to be proud oftaichichuan has much to be proud oftaichichuan has much to be proud oftaichichuan has much to be proud oftaichichuan has much to be proud oftaichichuan has much to be proud of
Send a message via AIM to taichichuan
Re: How To Use The WindRiver Dev Shell
Yes, you can use the host shell to compile the robot code. This sets up a set of environment variables that allow the compiler to execute from the command line. This allows you to use a run of the mill editor like VIM/GVIM, emacs, Visual Slickedit or whatever you feel comfortable with to create the program. Then, using a traditional makefile, build the code from the command line.
Realize that the workbench tool creates Makefiles to achieve code builds under the hood. The tool simply hides all of that from you.
In addition, you can open a connection to the target via something like the network console function. You can even deploy code via any FTP client like Filezilla. Poking around the file system on the target is a must if you want to use the CAN bus because you need to copy some additional code over to the cRIO.
The tricky part is using GDB to debug code outside of the workbench GUI. Again, it's possible. But, debugging from a command line application is non-trivial. I'd stay with the GUI for the debugging of the code.
HTH,
Mike
pic: without the shell NCHS robonauts Extra Discussion 2 08-06-2010 08:09 AM
How to NOT use WindRiver masoug C/C++ 9 05-01-2010 09:04 PM
How to configure the cRIO with windriver? z.s.tar.gz C/C++ 3 02-17-2010 08:50 AM
quation Holonomic Drive use Windriver C++ yara92 C/C++ 3 01-01-2010 06:18 AM
How the heck do you use an XBOX360 controller with the chicklet?? waialua359 Control System 58 02-17-2008 12:43 PM
