Go to Post "Field orientation is like a homing pidgeon that can fly backwards." - LostWolf [more]
Unread 13-09-2010, 19:53
Rangel(kf7fdb)'s Avatar
Rangel(kf7fdb) Rangel(kf7fdb) is offline
John Rangel
FRC #0842 (Falcon Robotics)
Rangel(kf7fdb) has a reputation beyond reputeRangel(kf7fdb) has a reputation beyond reputeRangel(kf7fdb) has a reputation beyond reputeRangel(kf7fdb) has a reputation beyond reputeRangel(kf7fdb) has a reputation beyond reputeRangel(kf7fdb) has a reputation beyond reputeRangel(kf7fdb) has a reputation beyond reputeRangel(kf7fdb) has a reputation beyond reputeRangel(kf7fdb) has a reputation beyond reputeRangel(kf7fdb) has a reputation beyond reputeRangel(kf7fdb) has a reputation beyond repute
Modifying The 2010 Image Demo
Hello, we want to start modifying the 2010 image demo on windriver. We want to make it so that the robot detects a square instead of a circle. How would we do that and where would we change the code?
2011-2014 Arizona Regional Winners
2012 Dean's List Winner
2012-2013 Team President
2013 8th Place Robosub Competition
2014-? Mentor
Unread 14-09-2010, 09:24
Dave Scheck's Avatar
Dave Scheck Dave Scheck is offline
FRC #0111 (WildStang)
Dave Scheck has a reputation beyond reputeDave Scheck has a reputation beyond reputeDave Scheck has a reputation beyond reputeDave Scheck has a reputation beyond reputeDave Scheck has a reputation beyond reputeDave Scheck has a reputation beyond reputeDave Scheck has a reputation beyond reputeDave Scheck has a reputation beyond reputeDave Scheck has a reputation beyond reputeDave Scheck has a reputation beyond reputeDave Scheck has a reputation beyond repute
Re: Modifying The 2010 Image Demo
I don't have the demo in front of me, but I have some test code that we wrote that was based on it. We moved some things around, so you'll have to do a little legwork to find the exact files that the corresponding code is in.
To detect elipses, the DetectEllipses of the MonoImage class is called from somewhere in the demo code
Code:
    results = luminancePlane->DetectEllipses(&ellipseDescriptor,
                                             &curveOptions, &shapeOptions,
                                             roi);
If you look at the what DetectEllipses is doing, you'll see this among some other code
Code:
	EllipseMatch *e = imaqDetectEllipses(m_imaqImage, ellipseDescriptor, curveOptions, shapeDetectionOptions, roi, &numberOfMatches);
This is the call to the IMAQ library that is doing the vision processing. If you look in nivision.h in the section where imaqDetectEllipses is defined, you'll see this prototype (kept the ellipse one here for reference)
Code:
IMAQ_FUNC EllipseMatch*             IMAQ_STDCALL imaqDetectEllipses(const Image* image, const EllipseDescriptor* ellipseDescriptor, const CurveOptions* curveOptions, const ShapeDetectionOptions* shapeDetectionOptions, const ROI* roi, int* numMatchesReturned);
IMAQ_FUNC RectangleMatch*           IMAQ_STDCALL imaqDetectRectangles(const Image* image, const RectangleDescriptor* rectangleDescriptor, const CurveOptions* curveOptions, const ShapeDetectionOptions* shapeDetectionOptions, const ROI* roi, int* numMatchesReturned);
So, you'll see that other than the second parameter, the calls are identical in terms of inputs.
So where does that leave you? What I would do is create a new class that inherits from MonoImage. I would do this in the team code instead of making the change directly in WPILib. This makes it easier to update WPILib in the future. In that class I would have a DetectRectangles method that mirrors what DetectEllipses is doing. Something like
Code:
class WsMonoImage : public MonoImage
    vector<RectangleMatch> * MonoImage::DetectRectangles(
		RectangleDescriptor *rectangleDescriptor, CurveOptions *curveOptions,
		ShapeDetectionOptions *shapeDetectionOptions, ROI *roi);
vector<RectangleMatch> * WsMonoImage::DetectRectangles(
       // I'm just showing the IMAQ call here.  You'll need to complete the implementation
	RectangleMatch *e = imaqDetectRectangles(m_imaqImage, rectangleDescriptor, curveOptions, shapeDetectionOptions, roi, &numberOfMatches);
       // more implementation would be here
As a C++ takeaway for the day, this demonstrates the importance of inheritance. The MonoImage does some things that are really good, but it doesn't quite do what we want and it's in a file that we don't really want to modify if we can avoid it. So, by using inheritance, we can make a class that does everything that MonoImage does plus what we want.
Good luck
Unread 14-09-2010, 19:00
John Rangel
I'm sorry but how would we make the implementations and of what would we implement.
2014-? Mentor
Unread 15-09-2010, 00:52
Look at DetectEllipses inside MonoImage.cpp. That should be the foundation for your DetectRectangles. Just copy/paste the entire guts of DetectEllipses into DetectRectangles. At this point, all you need to do is replace references to ellipse with rectangle. The EllipseMatch will become RectangleMatch. The vector type will change, the vector variable name should be changed to rectangles.
Along the way, I would suggest reading and understanding exactly what the function is doing. That's the only way you'll really learn. Copy/Paste never taught anybody anything.
Give that a shot and if you really can't figure it out, send me a PM and I'll clarify more.
Unread 06-02-2012, 22:33
Jake Harmon Jake Harmon is offline
FRC #3284
Jake Harmon is an unknown quantity at this point
Hey, thanks for the info on this thread, but how do you access the MonoImage.cpp file? We're having trouble finding it.
Thanks.
Unread 06-02-2012, 23:04
Alan Anderson's Avatar
Software Architect
FRC #0045 (TechnoKats)
It's now 2012. The thread is about code from two years ago.
Unread 07-02-2012, 15:48
DjScribbles DjScribbles is offline
Programming Mentor
AKA: Joe S
FRC #2474 (Team Excel)
Rookie Year: 2012
DjScribbles is a splendid one to beholdDjScribbles is a splendid one to beholdDjScribbles is a splendid one to beholdDjScribbles is a splendid one to beholdDjScribbles is a splendid one to beholdDjScribbles is a splendid one to beholdDjScribbles is a splendid one to beholdDjScribbles is a splendid one to behold
If your just getting started with the 2010 Image Demo, I would recommend updating your WPILib and using the new 2012 image demo sample.
See: http://www.chiefdelphi.com/forums/sh...d.php?t=101991
Unread 07-02-2012, 17:35
FRC #3284
I understand that this is the code from 2010, but our team was considering examining this image demo to understand how to detect the squares above the goals this year. We have the 2010 image demo, how can we access the MonoImage.cpp file? Or are you saying that this is not a good way to go about image tracking?
Unread 07-02-2012, 18:13
mikets's Avatar
mikets mikets is online now
Software Engineer
FRC #0492 (Titan Robotics)
mikets is a glorious beacon of lightmikets is a glorious beacon of lightmikets is a glorious beacon of lightmikets is a glorious beacon of lightmikets is a glorious beacon of lightmikets is a glorious beacon of light
There is a new vision sample for 2012. If you have installed the latest update (http://firstforge.wpi.edu/sf/frs/do/...2_update_for_c), you will see the vision tracking sample.
Unread 07-02-2012, 18:31
FRC #3284
Wow, this helps... Thanks guys! (Sorry if I caused any facepalms)
Unread 07-02-2012, 18:55
DavisC DavisC is offline
FRC #0539 (Titans)
Rookie Year: 2010
DavisC is just really niceDavisC is just really niceDavisC is just really niceDavisC is just really nice
Actually I thank you, cause I want to get the camera working and didn't know there is a 2012 sample! I thought I would have to change it around when I don't even understand how to do it on my own.
Thanks!
2010 Image Demo Rangel(kf7fdb) C/C++ 15 07-09-2010 19:55
Decoupling the image acquisition from the Image Processing Tom Line Programming 8 09-03-2010 17:52
Modifying the Piston Threads JMillar Pneumatics 1 20-02-2010 19:11
Anyone modifying the stock gearboxes? Swampdude Technical Discussion 17 04-02-2005 13:15
