Go to Post We honor those who are unsung - those without a trophy or a plaque to show their efforts. Those who may or may not get those things... but will still be on the sidelines, helping to guide FIRST in all the right directions. - Amanda Morrison [more]
Unread 26-09-2010, 01:40
davidthefat davidthefat is offline
Alumni
AKA: David Yoon
FRC #0589 (Falkons)
Rookie Year: 2010
davidthefat has much to be proud ofdavidthefat has much to be proud ofdavidthefat has much to be proud ofdavidthefat has much to be proud ofdavidthefat has much to be proud ofdavidthefat has much to be proud ofdavidthefat has much to be proud ofdavidthefat has much to be proud ofdavidthefat has much to be proud of
Using Multiple Kinds Of Motors
Since some motors have a higher torque, others have higher speed, isn't it a good idea to use both to drive the same robot? My team has never attempted this (or that I am aware of), would it be a good idea? According to the First Wiki, the Fisher Price motor has a higher speed, significantly higher. The CIM has a significantly higher torque. Now isn't it possible to make a mechanism that will switch the motors? Switching the motors to fit the needs of the situation. Car manufactures do it, for example the hybrid vehicles. They use both electrical motors and the traditional engines. They must have a mechanism to switch gears.
I have an idea for a mechanism that uses pneumatics and gears, but does not seem very reliable.
Now would it be really worth the trouble to make a mechanism to switch motors? Does the benefits outweigh the drawbacks?
Pros:
Best of both worlds
Cons:
Weight
Mechanism can be the weak point (more moving parts mean more chances of breaking down)
Seems like a redundant way to do something while gears ratios can be adjusted
Do not say what can or cannot be done, but, instead, say what must be done for the task at hand must be accomplished.
Using vars across multiple .c files Smithvillefirst Programming 6 02-02-2006 20:29
Using multiple controllers SFXSARNIA Technical Discussion 1 12-01-2006 14:07
Using multiple robots at a display? Adam Richards Control System 5 02-04-2005 12:44
Multiple Motors phrontist Motors 12 21-06-2004 23:05
Multiple-Motors echos Motors 8 11-01-2004 17:34
