Go to Post The trick is to train the rest of the team to blame electrical instead. - Al3+ [more]
Unread 01-10-2010, 18:02
gblake's Avatar
gblake gblake is offline
6th Gear Developer; Mentor
AKA: Blake Ross
no team (6th Gear)
gblake has a reputation beyond reputegblake has a reputation beyond reputegblake has a reputation beyond reputegblake has a reputation beyond reputegblake has a reputation beyond reputegblake has a reputation beyond reputegblake has a reputation beyond reputegblake has a reputation beyond reputegblake has a reputation beyond reputegblake has a reputation beyond reputegblake has a reputation beyond repute
Re: [FTC]: New Tetrix Parts
Originally Posted by Joyride_67_1902 View Post
I'm guess I'm having a hard time interpreting what you mean by replacement.
Do you mean like a spare part in tetrix kit, or something that does the same thing even looks the same from out of kit?
Same size, shape, mass, surface finish, function, etc. parts gotten from a retailer/OEM other than Pitsco/Tetrix (I'm not sure if either Pisco or Terix are OEMs, but let's give them the benfit of the doubt in this conversation). The classic example is substitute screws bought from a local hardware store.
"Substitute" would have been a better choice of words on my part.
Blake
Blake Ross, For emailing me, in the verizon.net domain, I am blake
VRC Team Mentor, FTC volunteer, 5th Gear Developer, Husband, Father, Triangle Fraternity Alumnus (ky 76), U Ky BSEE, Tau Beta Pi, Eta Kappa Nu, Kentucky Colonel
Words/phrases I avoid: basis, mitigate, leveraging, transitioning, impact (instead of affect/effect), facilitate, programmatic, problematic, issue (instead of problem), latency (instead of delay), dependency (instead of prerequisite), connectivity, usage & utilize (instead of use), downed, functionality, functional, power on, descore, alumni (instead of alumnus/alumna), the enterprise, methodology, nomenclature, form factor (instead of size or shape), competency, modality, provided(with), provision(ing), irregardless/irrespective, signage, colorized, pulsating, ideate
Unread 01-10-2010, 18:23
Andrew Remmers's Avatar
Andrew Remmers Andrew Remmers is offline
AKA: Andrew Remmers
Rookie Year: 2007
Andrew Remmers has a reputation beyond reputeAndrew Remmers has a reputation beyond reputeAndrew Remmers has a reputation beyond reputeAndrew Remmers has a reputation beyond reputeAndrew Remmers has a reputation beyond reputeAndrew Remmers has a reputation beyond reputeAndrew Remmers has a reputation beyond reputeAndrew Remmers has a reputation beyond reputeAndrew Remmers has a reputation beyond reputeAndrew Remmers has a reputation beyond reputeAndrew Remmers has a reputation beyond repute
Send a message via AIM to Andrew Remmers
Blake
Generally the rules has been No you can't. You have to use tetrix parts or anything that they specify that can be used. Otherwise there isnt much straying from the kit sadly...
Exploding Bacon 2007-2011
Built and Dangerous (B.A.D) 2011-2012
Community Mentor / School Break 2012-2014
North American Robotics: The MooseEagles Founding Member 2012-Present (VEX U)
[FTC]: Anyone new to FTC or TETRIX, READ THIS NOW! PhilBot FIRST Tech Challenge 21 04-12-2009 17:34
[FTC]: VRC (VEX) AND FTC (Tetrix) jbbjjbt FIRST Tech Challenge 1 21-09-2009 14:59
[FTC]: CAD Models of Tetrix parts? Madison FIRST Tech Challenge 2 23-11-2008 08:49
[FTC]: FTC Tetrix Extra Parts Team 288 FIRST Tech Challenge 2 22-10-2008 18:30
[FTC]: Rookie Team Needs Help With Tetrix FTC Kit! rjustice4 FIRST Tech Challenge 8 05-10-2008 09:44
