Go to Post Darn IFI and AndyMark for making quality products! :) - Gabe [more]
Unread 02-10-2010, 17:32
sneakyimp sneakyimp is offline
sneakyimp is on a distinguished road
lazy susan type bearing? thrust bearing?
This is my first post here and, based on the registration process, I'm not sure if it's appropriate for me to post here. However, I could really use some advice from seasoned robot builders and mechanically oriented people.
I'm working on a kinetic sculpture that involves a savonius-type vertical axis wind turbine (VAWT). I'm trying to build the base which is a lazy susan type contraption. I bought a 6-inch lazy susan bearing and assembled a lazy susan but the bearing doesn't spin freely enough and it's really loud. I need a smoother, quieter mechanism and was hoping to get some suggestions about what I should be using.
I've been looking into this for quite some time and my reading has led me to conclude that I need some kind of precision thrust bearing. Not being a mechanical engineer, I don't really understand how these thrust bearings are installed for my type of machine. They have no housing, no screw holes and no set screws and are quite narrow. I therefore don't understand how to mount them and, although they would support axial load, I don't imagine they would provide any lateral stability at all. Would this type of bearing need one or more radial bearings to support my disk? Would a shaft through the center keep everything aligned properly? If my shaft tolerances are off, will friction result or possibly too much travel resulting in vibration and wear?
I imagine that I would need to attach my rotating disk to a shaft by means of a flange or hub of some kind and that the hub would rest on the top of the thrust bearing (on the thrust washer) which would support its weight. I can also imagine putting a radial bearing (like a pillow block bearing) a foot or so down the shaft to provide lateral stability. I've attached a drawing of my thinking.
There are also tapered thrust bearings which look awesome (supports both radial and axial load!) but I fail utterly to see how I might attach these to either shaft or my turntable.
Any suggestions or help would be much appreciated.
Making a custom lazy-susan style bearing t41w4ne5ef0b Kit & Additional Hardware 10 23-01-2009 03:04
Bearing Blocks Matt382 Technical Discussion 4 29-01-2008 22:30
Bearing problem Templar1396 Technical Discussion 2 20-01-2007 13:08
bearing help jimfortytwo Technical Discussion 9 01-05-2004 06:20
Bushing v. Bearing VinceT Technical Discussion 14 22-12-2003 19:11
