Go to Post I haven't invented anything for an hour or two. I need to get back to work. - MrForbes [more]
Unread 14-10-2010, 11:27
davidc10 davidc10 is offline
FRC #0423
Rookie Year: 2007
davidc10 will become famous soon enough
Cypress installation order
I did this so many times last year without a hitch, and now I've got a new installation (Win 7 Pro x64) where the Driver Station doesn't detect the Cypress board. (The board works on other laptops with same OS - although the CyMini service sometimes needs a restart).
The driver looks good - it shows up as FTK3 - configured. The PSoC programmer connects to it fine. The CyMini service is set to auto and running. One thing that is different is that when I installed from the Cypress disk, I ran the updater, so the PSoC Programmer version is 3.12, not 3.10.
Maybe I'm installing in the wrong order this year. Here's what I did:
1. Install LabVIEW original files
2. Install LabVIEW update 2.1
3. Install DSUpdate 1.1
4. Install Cypress disk - everything set to Typical
5. Ran the Cypress Updater
I ran the setups as admin and re-booted after every step. When it didn't work I un-installed all and tried it again.
Is this correct?
David
Unread 14-10-2010, 12:58
Mark McLeod's Avatar
Mark McLeod Mark McLeod is online now
Just Itinerant
AKA: Hey dad...Father...MARK
FRC #0358 (Robotic Eagles)
Re: Cypress installation order
I just reimaged a Classmate and reinstalled everything, but I haven't tested the Cypress board yet. I don't run the separate Cypress installations that you added at the end.
I'll try it with the Cypress board as soon as I get home after work tonight and see if I have the same or similar problems.
Unread 14-10-2010, 13:22
When doing this on Win7, I needed to update the .hex file in the specific programmer. I believe I took the ftk_3_simfw.hex file from a working classmate and placed it into the ProgFiles/Cypress/Programmer/3.12/Service folder overwriting the one that was already there.
I can't remember the exact file or location, so if that isn't it, it was a .hex file that I moved and placed near a Cypress service.
Greg McKaskle
Unread 14-10-2010, 20:33
FRC #0423
Rookie Year: 2007
I've seen those files in similar locations - I'll try it.
Thanks Greg.
David
10 minutes later and it works - just as you had it. I had tried moving the driver PSoCUSB.sys from the classmate last night, but that didn't work.
Thanks again.
re-installation of DS dashboard byteit101 Programming 4 31-01-2010 10:17
Autodesk Maya Installation girlwithwrench 3D Animation and Competition 1 22-01-2010 02:08
windriver installation error sirishy2k C/C++ 1 29-06-2009 22:28
Inventor installation CD Brankampdg CAD 0 07-11-2008 12:33
Installation Error Heretic121 LabView and Data Acquisition 5 21-01-2006 23:26
