Go to Post The fact that it is easy doesn't mean that it is smart. - JVN [more]
Unread 18-10-2010, 10:26
Geek 2.0 Geek 2.0 is offline
FRC #0107
Geek 2.0 will become famous soon enough
CIM + Banebots P60 Gearbox
Does anyone know if there's a way to make a CIM work with a Banebots P60 Planetary gearbox?
Also, if not that, does anyone know any good, cheap gearboxes? They're very expensive...
This is a non-FIRST application, so I'm not concerned about legality.
Thanks!
Unread 18-10-2010, 10:44
Chris is me's Avatar
AKA: Pinecone
Re: CIM + Banebots P60 Gearbox
Any reason not to use the BB P80s with the CIMs instead of the P60s?
At $75 a pop, you can't beat the AM Toughbox Nano for a quick CIM gearbox that can take anything you'd ever throw at it.
Unread 18-10-2010, 11:29
FRC #0107
No reason other than being REALLY cheap. Robots are expensive, and I want one, but I don't want to spend a lot on it. Gearboxes are the most expensive part, so we'll see...
Unread 18-10-2010, 11:38
Andrew Schreiber Andrew Schreiber is offline
Joining the 900 Meme Team
FRC #0079
Rookie Year: 2000
Andrew Schreiber has a reputation beyond reputeAndrew Schreiber has a reputation beyond reputeAndrew Schreiber has a reputation beyond reputeAndrew Schreiber has a reputation beyond reputeAndrew Schreiber has a reputation beyond reputeAndrew Schreiber has a reputation beyond reputeAndrew Schreiber has a reputation beyond reputeAndrew Schreiber has a reputation beyond reputeAndrew Schreiber has a reputation beyond reputeAndrew Schreiber has a reputation beyond reputeAndrew Schreiber has a reputation beyond repute
Build a smaller one. Something sitting in the 30lb range should cost you ~$400 or so if done right. An FRC scale robot is actually quite a large machine.
Unread 18-10-2010, 11:46
FRC #0107
Yeah, and I'm doing my best to make that $400 about $350, but when a single motor+gearbox is $100+, it's difficult.
Unread 18-10-2010, 12:14
FRC #0079
Rookie Year: 2000
Might I suggest using the p60's with an RS550 motor. It will cut down your metal costs, your ESC costs and manufacturing time. Building a smaller machine means you can throw it in a bag and use it to demo rather than needing a van to transport it.
Unread 18-10-2010, 12:21
FRC #0107
I was actually planning on doing that. I just was wondering how much the step up to CIMs would cost.
Two quick things:
1. Would it be a good idea to just use sprocket and chain instead of gearing? It IS cheaper...
2. What's the best motor selection/gearing selection process? I've tried working out the physics, and I have some guesses as to what will work, but I'm just not sure.
Unread 18-10-2010, 12:47
FRC #0079
Rookie Year: 2000
Two quick things:
That is dependent on your reduction, a sprocket and chain reduction is great for a place where you have a small reduction (imho <10:1) and have to transmit power over a distance anyway.
http://www.chiefdelphi.com/forums/sh...6&postcount=25 Should help you with #2
Unread 18-10-2010, 13:15
FRC #0107
Wow, that post is REALLY helpful!
Does anyone know the static coefficient of friction of AndyMark Omni-Wheels on carpet and/or other materials? If not, I'll probably start a new thread requesting it...
Thanks!
Unread 18-10-2010, 13:57
biojae's Avatar
biojae biojae is offline
Likes Omni drives :)
AKA: Justin Stocking
FTC #5011 (BOT SQUAD) && FTC#72(Garage bots)&& FRC#0399 (Eagle Robotics)
biojae is a jewel in the roughbiojae is a jewel in the roughbiojae is a jewel in the rough
Thanks!
They are all on the andymark website.
Which omni wheel do you want to use?
Their 6" aluminum omnis (AM-0097) have these coefficients:
1.0 radial static
0.8-0.88 radial dynamic
0.2-0.27 transverse static
0.16-0.2 transverse dynamic
FTC Team 72 - No site
FRC Team 399 - http://www.team399.org
2010 Rockwell Collins Innovation in Control Award - (Use of the CAN bus, among other reasons) Phoenix, Arizona!
BaneBots P60 + FP motor tips Rob Motors 15 04-02-2012 21:00
p60 gearbox disassembly KNZ1030 Technical Discussion 4 02-02-2009 11:07
Banebots/Cim motor programming question Japper Programming 4 14-02-2007 12:02
Strange noises from the BaneBots gearbox/CIM combination. PhilBot Motors 5 15-01-2007 11:15
42 mm Banebots Gearbox Hunter Motors 9 13-01-2007 21:52
