Go to Post Keep in mind that words can be harsh and people do not forget what is said against them. Please, for your teammates sake, keep your egos in check and try to use some tact and consideration. - Andy Baker [more]
Unread 21-10-2010, 20:01
kamocat's Avatar
kamocat kamocat is offline
Test Engineer
AKA: Marshal Horn
FRC #3213 (Thunder Tech)
kamocat is just really nicekamocat is just really nicekamocat is just really nicekamocat is just really nicekamocat is just really nice
Send a message via AIM to kamocat Send a message via MSN to kamocat
Interrupt triggered DMA
I'm trying to use an analog accelerometer to measure impacts.
To do that, I'm using an interrupt on an Analog Trigger to wait for an impact, and Direct Memory Access to acquire the data.
However, there appears to be an issue with DMA carrying over data from the last acquisition, despite my "read" telling me there is no more data.
Here's a screenshot of my VI:
The vertical line in the graph about 0.2 seconds in is what I'm referring to. (Please ignore the incorrect date in the timestamp)
In addition to this issue, I was wondering if there was a good way to capture the moment of the impact. Continuously acquiring with DMA doesn't sound very efficient (though it would remove the need for an interrupt).
I've uploaded the VI for your review. It's not neat or documented at the moment, but I can improve that if you would like.
-- Marshal Horn
Using Interrupts or DMA or timing to control digital I/O switch mikeppalmer NI LabVIEW 13 23-02-2010 13:36
Sequence of solenoids triggered by a button? Team1908 NI LabVIEW 4 21-02-2010 21:33
interrupt enable 3dude_2231 Programming 6 10-02-2008 16:08
Interrupt question Kashi Chan Programming 2 07-03-2005 08:28
enable interrupt Dean Programming 2 13-02-2005 07:37
