Go to Post Someday I will have to learn how tagging and reps work. I already know how search and brain farts work. - kstl99 [more]
Unread 23-10-2010, 23:43
disb disb is offline
disb is an unknown quantity at this point
Solenoid questions
I am new, couldn't find much information on Chief Delphi or Google.
Here is my situation: I have 1 double acting, 10 inch stroke, 2 inch bore pneumatic cylinder and needs to generate a 60 psi. I have the cylinder, now I need to choose a solenoid valve to control the cylinder (and this valve will be controlled by PLC). To confirm with you guys, does it sound right that I should have at least 1 inlet, and at least 2 outlets? With this conclusion, I am planning to get a 4/5 port solenoid valve.
I understand 2 port valves, where there is just one inlet and one outlet, but how exactly does a 4/5 port valve work? Does it have to work with a manifold (because I am not planning to)? Any valves you guys recommend by say SMC (SYJ 3000 series?)?
Solenoid question.. nadavsen2 Pneumatics 6 16-02-2010 11:25
Solenoid not firing off Solenoid Breakout spooncwru Pneumatics 2 30-01-2010 17:46
Bumper Zone Questions (was Misc. Questions) viperred396 General Forum 9 10-01-2010 12:09
Single Solenoid Zultraranger Pneumatics 3 04-02-2008 16:36
Programming a Solenoid Brigander Pneumatics 4 17-02-2007 14:06
