[FTC]: Increase Program Testing Speed?
How do people test their programs, quickly?
We currently deploy Labview programs and then run the FCS from 2009. I'm wondering if folks have developed a labview program that doesn't require FCS and simply runs the code. A simple code, that you can hit the "deploy & run" button in labview to check code. Which later is embedded in the full code that receives the "enable/disable" commands from the FCS Thanks for any thoughts on how to speed up programming checks. |
Re: [FTC]: Increase Program Testing Speed?
If we want to run the code on the field, we use this year's FCS with the samantha module, and download the code via bluetooth so we can keep the file open.
If we are testing something basic, we'll tether the robot with a usb cable. You can then run the code while labview is running it as well, this way you can get live feed from the robot's sensors ect and put data in while the program is running. |
| Robot Communications dies as Motor speed increase | Michael Fadaie | NI LabVIEW | 4 | 19-02-2010 00:55 |
| Code to increase speed when joystick is pushed further | JoJo5 | Programming | 3 | 06-02-2007 07:29 |
| Gradual Speed Increase | Booger | Programming | 2 | 24-07-2006 15:44 |
| Ball speed testing after matches | Ken Loyd | Rules/Strategy | 26 | 29-03-2006 22:36 |
| Gradual increase in speed? | Kevin Rugani | Programming | 1 | 27-03-2003 21:36 |
