Go to Post Without programmers there would only be a robotic beauty contest. - mallot1243 [more]
Unread 17-12-2010, 08:32
dmitch's Avatar
dmitch dmitch is offline
Chief Head Electrical Guy
AKA: Daniel Mitchell
FRC #1997 (Stag Robotics)
Rookie Year: 2010
dmitch is a jewel in the roughdmitch is a jewel in the roughdmitch is a jewel in the roughdmitch is a jewel in the rough
Re: Code Problems
Thank You those diagrams are amazingly helpful! I'll be able to let you know if I need help with anything else after next wednesday.
Unread 05-01-2011, 21:02
dmitch's Avatar
Rookie Year: 2010
Re: Code Problems
We have completely rewired our robot and it will turn on and thats as far as it will go. I need help with the ethernet cable wiring. The situation is as follows:
When we connect an ethernet cable from the laptop to the wireless router, and another one from the bridge to the cRIO, we recieve no robot communication but the ethernet and radio signals on the driver station are both green and the light on the 1st ethernet slot on the cRIO is lit up.
However, when we tether the ethernet cable, (directly from the laptop to the cRIO) we get the same green radio and ethernet signals but the light on the cRIO slot does not light up.
That probably didn't make sense so i've put together some diagrams that might make a little more sense, they are attached.
This probably isn't really clear but if you have any quesions please ask thank you. I am confused and my coach is not that familiar with the wiring on our robot. Any help would be great.
ID:	9576  Click image for larger version
Name:	Driver Station.jpg
Unread 13-01-2011, 13:29
Frenchie461's Avatar
Frenchie461 Frenchie461 is offline
iScout
AKA: Brian, Frenchie, or that guy
FRC #0461 (Westside Boiler Invasion)
Team Role: CAD
Rookie Year: 2010
Frenchie461 is a jewel in the roughFrenchie461 is a jewel in the roughFrenchie461 is a jewel in the roughFrenchie461 is a jewel in the rough
Re: Code Problems
Originally Posted by dmitch View Post
Ok sorry. First of all, it is coded in LabView.
Well there's your problem
"As a general rule, the most successful man in life is the man who has the best information." - Benjamin Disraeli (1804-81)
Unread 14-01-2011, 20:31
dmitch's Avatar
Rookie Year: 2010
Re: Code Problems
we got a new cRIO for this year and we tried it in our old robot just to see what would happen. We weren't getting comms wirelessly so we tethered. But both tethered and wireless gave us the same problem: the ethernet and ds radio lights are always green. however, we cant get the bridge light to go on no matter what and so we have no robot comms. the status light on the cRIO is blinking the whole time. We are going to look at the cRIO light indicators tonight but any other ideas are welcome thank you.
Unread 15-01-2011, 08:42
Alan Anderson's Avatar
Software Architect
FRC #0045 (TechnoKats)
Re: Code Problems
...the ethernet and ds radio lights are always green. however, we cant get the bridge light to go on no matter what and so we have no robot comms...
Have you reconfigured your wireless bridge since it was used in competition? It was set up with a security code at that time. You need to follow the instructions to connect to it using a web browser and reset the security to "none".
Unread 15-01-2011, 09:58
dmitch's Avatar
Rookie Year: 2010
Re: Code Problems
How do you reconfigure the wireless bridge?
Problems Combining Camera Code and Driving Code cmurdoch Programming 20 10-02-2007 16:34
Problems integrating CMUCAM code and IFI Default Code Windward Programming 2 06-02-2007 16:48
Problems when combine ADC code && camera code nirhaim1942 Programming 1 24-01-2007 06:58
problems using gyro/adc code with camera default code tanstaafl Programming 7 22-01-2006 23:09
Labview problems and code problems ajsetter Programming 25 18-01-2006 17:07
